ON THE NEW HIGH OUTPUT WATER PUMP THERE ARE 2 CONNECTION PORTS. ONE IS FOR THE HEATER CONNECTION AND THE OTHER ONE (DRIVER SIDE) IS WHERE I WANT TO SCREW IN A ROUND FACE HOT WATER TEMPERATURE GAGE TO READ THE WATER TEMP. HAS ANYONE DONE IT AND WHICH BRAND DID YOU GET. DOES IT WORK. I INTEND TO KEEP THE ELECTRICAL DASH UNIT ALSO. THANKS, CHARLIE.
By Florida_Phil - 7 Years Ago
What I did was screw the stock dash gauge temperature sending unit into the driver's side of the water pump and the aftermarket gauge sending unit into back of the head with an adapter.
Why did you do that? I want both so that I can keep an eye on it while I'm under the hood and the dash unit as a backup, comparing one against the other. I suspect the engine gets hotter back by the rear cylinders. I see that you use flat washers under the lock washers, Why. I like the idea.
By pegleg - 7 Years Ago
Actually the water temp will be higher at the front of the head. Water in the heads flows toward the radiator. Where you have it will only tell you the temp coming OUT of the radiator.
By Gene Purser - 7 Years Ago
I agree with pegleg, the sensor in that part of the water pump will monitor the cooled water from the bottom of the radiator. That is good if you want to monitor the efficiency of the radiator, but not much use as an indicator of your actual engine temperature.
By miker - 7 Years Ago
I drilled and tapped my Blue Thunder intake on the water passage behind the tstat on the drivers side. Ran a little gauge there for some time. It’s now the temp sender location for the EFI. Got to have the manifold off, there’s not a lot of room and some senders or gauges might not clear inside. Probably easier is to just buy an infrared thermometer. Even the cheap ones from Amazon read within a degree of the much more expensive Fluke meters my neighbor the HVAC guy uses. More than close enough for a cooling system. There is a temp difference between the back of the head (factory) and the front of the intake, as mentioned above. You’ll see it with the infrared unit.
My objective was to run both the dash gauge and the SW gauge I have under my dash. This seemed like the easiest solution. The dash gauge is worthless as far as I am concerned, but I wanted it to work nevertheless.
55charliebird (6/9/2019)
Why did you do that? I want both so that I can keep an eye on it while I'm under the hood and the dash unit as a backup, comparing one against the other. I suspect the engine gets hotter back by the rear cylinders. I see that you use flat washers under the lock washers, Why. I like the idea. The stainless bolt kit I used had both flat and lock washers. I agree taking the temp at the pump is almost worthless.
By KULTULZ - 7 Years Ago
I believe FORD ENGINEERING placed the FY COOLANT TEMP SENSOR where they did because of the possible area overheating caused by placing the exhaust valves side by side on the center cylinders (TED will correct me if I am mistaken here).
In a more normal cooling system, the proper place for the sensor will be directly behind the coolant thermostat. Your wanting to run two gauges will present a problem as the OEM and aftermarket sensor/gauge will have different calibrations (cannot be placed in same position unless two holes are provided) so a second location needs to be used.
This is a inline fitting (the 1958 FE used a similiar setup) that will allow the sensor to be placed in the WP bypass hose -
GOOD IDEA but won't be corect when heater valve is closed,i have used a simler setup that ts below heater valve as you stated that is the best aria for real eng. temp
That fitting will be too long to fit in the bypass hose of a Y.
my take was the fitting would go in the hot side of the heater hose,not the bypass
Let me try again-
To achieve what the OP wants to do is either drill and tap the intake for another sender,
or, make a modification in the WP By-Pass Hose to accept a sensor adapter (have to fabricate). The first photo I showed was just a random example. FORD used the below style on the 58/59 FE -
The OEM gauge sender will stay on the cyl head.
2721955meteor (6/10/2019)
How would that work?
THE PICTURE OF INTAKE IS EXCELENT IDEA, I DID MYN BUT THE MANIFOLD IS THIN AT THAT POINT,WOUND UP REMOVING MANIFOLD AND SILVER SOLDERING TO STOP LEAKAGE. manifold came from arizona ,no antifreeze with lots of water erosion.
By Fairlane57 - 7 Years Ago
Hi all, i have a similar problem with my gauge as the sensor unit is not working ,can you advise what i need to replace it with, its for a 57 fairlane 292. are these senders unique to this engine or will others fit ? .I wont get one off the shelf here im sure..
