Visits: 3.6K
Looking for marine dist for 312 interceptor marine. I have one but all the advancement parts are shot. Has to be marine with centrifugal advance. See attach photo for rotation. This is an auto lite but a lot of Mallory’s were used.
Preserving the old can be more rewarding than buying the new...
Visits: 13.9K
I have one, don't know the condition, will find out Monday, look at my add on E Bay, it's on that engine https://www.ebay.com/itm/264321776709Liqu@aol.com
Posts: 2.0K,
Visits: 306.5K
You have a pre-FORD buying of some AUTO-LITE divisions distributor. The ID NO. IBL 4001A GOOGLED should give you a rebuilder and/or parts source.
Visits: 3.6K
I have had no lock finding repair for this dist can someone point me to repair or part. Thanks Ike
magiemae (5/19/2019) Looking for marine dist for 312 interceptor marine. I have one but all the advancement parts are shot. Has to be marine with centrifugal advance. See attach photo for rotation. This is an autolite but a lot of Mallory’s were used.Do you need a distributor with a tanged oil pump drive or a ¼” hex oil drive?
Posts: 2.0K,
Visits: 306.5K
Give these guys a call and see if they can direct you - https://barnetthighperformance.com/292-312-y-blocks/
Visits: 13.9K
Visits: 3.6K
Ted It has the tanged drive see pic
Visits: 3.6K
Looks like yours has the hex drive I need the tang. May work if I chang out the drive shaft but not sure how the hex drive shaft connects to oil pump I have a tang there also Thank
Posts: 3.8K,
Visits: 33.1K
It sounds the same as swapping Distributors on the 54 Y Blocks with tanged Parts. U will have to change Oil Pump and driveshaft to match the Distributor Hex Drive.
