Distributor for 312 marine engine
http://forums.y-blocksforever.com/Topic145805.aspx
By magiemae - 7 Years Ago
Looking for marine dist for 312 interceptor marine. I have one but all the advancement parts are shot. Has to be marine with centrifugal advance. See attach photo for rotation. This is an auto lite but a lot of Mallory’s were used.
By Cliff - 7 Years Ago
I have one, don't know the condition, will find out Monday, look at my add on E Bay, it's on that engine
https://www.ebay.com/itm/264321776709
Liqu@aol.com
By KULTULZ - 7 Years Ago
You have a pre-FORD buying of some AUTO-LITE divisions distributor.
The ID NO. IBL 4001A GOOGLED should give you a rebuilder and/or parts source.
I have had no lock finding repair for this dist can someone point me to repair or part.
Thanks Ike
By Ted - 7 Years Ago
magiemae (5/19/2019)
Looking for marine dist for 312 interceptor marine. I have one but all the advancement parts are shot. Has to be marine with centrifugal advance. See attach photo for rotation. This is an autolite but a lot of Mallory’s were used.
Do you need a distributor with a tanged oil pump drive or a ¼” hex oil drive?
Give these guys a call and see if they can direct you -
https://barnetthighperformance.com/292-312-y-blocks/
Here's the one I have
http://forums.y-blocksforever.com/uploads/images/133d1229-18a6-4fcf-9557-efb5.jpg
http://forums.y-blocksforever.com/uploads/images/6348e584-ce24-4e3f-b927-b724.jpg
http://forums.y-blocksforever.com/uploads/images/09d88a51-5cc6-4043-b28d-e521.jpg
It has the tanged drive see pic
Looks like yours has the hex drive I need the tang. May work if I chang out the drive shaft but not sure how the hex drive shaft connects to oil pump I have a tang there also
Thank
By oldcarmark - 7 Years Ago
It sounds the same as swapping Distributors on the 54 Y Blocks with tanged Parts. U will have to change Oil Pump and driveshaft to match the Distributor Hex Drive.
I went through my stack of Mallory distributors and none have the tanged drive for the oil pump.  If you can not come up with a tanged drive distributor, then I would suggest changing out the oil pump and oil pump to the ¼” hex drive versions and switch to the appropriate hex drive distributor that matches.
By 30 coupe - 7 Years Ago
You might try this guy.  He specializes in Flathead stuff, but may be able to rebuild your original.  just a thought.     www.bubbasignition.com/
By pegleg - 7 Years Ago
I have one, will look tomorrow at the pump drive and tell you.
Thanks will be waiting . No luck At this time
