Distributor for 312 marine engine
Posted By magiemae 7 Years Ago
I went through my stack of Mallory distributors and none have the tanged drive for the oil pump.  If you can not come up with a tanged drive distributor, then I would suggest changing out the oil pump and oil pump to the ¼” hex drive versions and switch to the appropriate hex drive distributor that matches.
30 coupe
Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)
Posts: 130, Visits: 3.4K
You might try this guy.  He specializes in Flathead stuff, but may be able to rebuild your original.  just a thought.     www.bubbasignition.com/
I have one, will look tomorrow at the pump drive and tell you.
magiemae
Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)
Posts: 10, Visits: 3.6K
Thanks will be waiting . No luck At this time
Preserving the old can be more rewarding than buying the new...
