Coil springs for a '56 Farilane
Posted By Tim Quinn 6 Years Ago
Tim Quinn
Posted 6 Years Ago
Supercharged (633 reputation)Supercharged (633 reputation)Supercharged (633 reputation)Supercharged (633 reputation)Supercharged (633 reputation)Supercharged (633 reputation)Supercharged (633 reputation)Supercharged (633 reputation)Supercharged (633 reputation)
Posts: 266, Visits: 3.5K
Read somewhere that Bronco coil springs will fit/work in a '56 Fairlane.
If true, what year Bronco springs should I order.
 Article also said that the Bronco springs lower the front end a little, this
is not a problem, a little lower front end will look good.
Thanks in advance for your feed back,
Tim
Florida
MplsMike
Posted 6 Years Ago
Last Active: 5 hours ago
Posts: 204, Visits: 91.8K
If you search this site for Aerostar springs, you will find a lot of posts from people who have done that conversion.
MplsMike
'56 Parklane
Minneapolis, MN
Posted 6 Years Ago
Detroit Spring sells originals. As well as Macs and most of the other Vintage Repro Parts Sellers. I have never heard of using Bronco Springs. Aerostar Yes.
Tim Quinn
Posted 6 Years Ago
Thanks a ton for the Aerostar suggestion. I was confussed between Bronco and Aerostar.
Tim in Florida
Tim Quinn
Posted 6 Years Ago
I was confused, age might have something to do with being confused. It was Ford Aerostar springs I heard or read about.
Now I looking to buy the Aerostar spring set that gives a little lower front end profile. Might make it easier to see over the steering wheel without pitting 2 cushions on the seat.
Tim w/ '56 Ford in Florida
MplsMike
Posted 6 Years Ago
This post would be a good place to start.
http://forums.y-blocksforever.com/Topic117546.aspx
MplsMike
'56 Parklane
Minneapolis, MN
Posted 6 Years Ago
Posts: 1.7K, Visits: 340.0K
As you can read on the above thread. I used the Aerostars The urethane spacers for the top were for a Toyota pickup because of the diameter. Ford has a thin spacer like shim on the the top and I sure it's for noise. Normal flat street and highway ride is nice.
One thing about the Aerostars is they a compound wound and react different when hitting a dip in the road. I have good shocks but if your not careful and run into going a little fast it will bottom quicker that you can react. I don't remember the stockers doing that and cutting two coils off the bottom will give you the same look but not the same ride.... Good Luck
Talkwrench
Posted 6 Years Ago
Posts: 898, Visits: 23.2K
Not a real fan of the Aerostar springs , I'd be happy with my cut springs again. Whistling
62bigwindow
Posted 6 Years Ago
Posts: 884, Visits: 14.3K
I have them on my car and like them. Rides and handles great.
Durham Missouri
Dave C
Posted 6 Years Ago
Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)
Posts: 101, Visits: 31.2K
Tim Quinn (3/27/2019)
Check out Rock Auto. I just bought a set for my 55. ACDELCO 45H1046 $54.00
Use discount code 10401537998851663 which is good until May 12..
Dave
