Last Active: 6 days ago
Visits: 32.6K
Hey Guy's. I figured out my Problem and got it running Today. Read my previous Post earlier Today. It's never the Obvious Things that cause a Problem.
FORD DEARBORN
Visits: 113.4K
Fantastic news, cool.Good to know insufficient air gap can cause "no fire." I predict there will be no leaks - you went through enough already. If you should have any other issues with the Pertronix setup, please post, JEFF.....................
Visits: 32.6K
FIXED IT!!!! After puzzling over my Problem and reading all the Responses I decided to pull the Distributor and have a look at the Pertronix Unit. I had the Distributor apart while I had the Engine out to replace the Breaker Plate. I have a nice 57 Unit with the Ball Bearing Breaker Plate and I found a NOS One to install. The Pertronix Unit needs to have a .030" Air Gap between the Module and the Magnet on the Center Cam. I guess I only spaced it at about .010".It will appear to be working when I checked the Coil for Spark but with insufficient Air Gap it won't start the Engine. The lesser the Air Gap the lower the Dwell. Re-gapped it and installed. Fired up with a little moving the Distributor a little advanced. As usual its always something Stupid that causes a Problem. Its running and I am relieved about that. Now I can set it up and see if my rear Main Seal and Transmission Leaks are fixed. Thanks for the Input Guys.
FORD DEARBORN
Visits: 113.4K
Thanks Charlie.............I'm usually pretty good at adding confusion.
When the gears are in the correct orientation while installing the chain #1 is in overlap and # 6 is in compression. That's where the confusion is coming from. He has since verified that the pointer is at the tdc mark, valves are closed and the rotor is pointing to #1 and it no longer matters the position things should be in during installation. A compression test will give poor results if the gears are installed incorrectly. That is something that can be done.
FORD DEARBORN
Visits: 113.4K
That is true, It would be overlap. I read Sandbird's post which reminded me of some old notes and found the illustration. After a closer look, I see it doesn't specify which cylinder is to be in overlap but I just assumed #1. Been too many years since I assembled my engine but will look further for more info.
Visits: 32.6K
Turning the Engine over to TDC with the Valves cracked Open is not Compression Stroke. Finger in the Spark Plug Hole Confirms that. Will a Compression Test tell me if there is a Problem with the Timing Gears?
FORD DEARBORN
Visits: 113.4K
Mark, I think Sandbird is right. The #1 should be at overlap, not TDC compression stroke. It's been about 5 - 6 years since I did this and just for reference, I indeed found it in my notes that #1 is to be TDC at overlap, not at compression TDC.. That would mean both intake and exhaust rockers would be just holding both valve cracked. I even found a copy of an illustration of this but don't remember it's source.  . I'll try to include it in this post. Maybe I missed somewhere in this thread that you indeed had the #1 in "overlap." If I did, my apologizes, JEFF.................
Robin272
Visits: 114
++ on coil wire. I did not have enough voltage at the coil, the car was completly dead. You can also see it on the color off the spark. Should look like a Blue colored spark 👍
Visits: 285.6K
I had a similar problem with one of my cars last year. I chased it for days. It turned out to be a bad coil wire. The wire had a graphite core and one end was burnt. Very erratic. It would pop and try to start, wouldn't stay running. Another time it was dirt in my gas tank. I believe you will find out this is something simple that you are missing.
