Only left bank burning oil
Posted By Tim Quinn 6 Years Ago
Posted 6 Years Ago
Posts: 1.8K, Visits: 306.3K
You also mentioned the draft tube. It is connected to a new Summit carb with a PCV in the middle of the rubber hose.
Is your setup similar to this -
http://forums.y-blocksforever.com/uploads/images/4208d7f6-b8b1-4f75-9bb1-b1a4.jpg
Or this -
http://forums.y-blocksforever.com/uploads/images/9c2707e4-cf28-4562-b96e-a27e.jpg
Tim Quinn
Posted 6 Years Ago
Supercharged (633 reputation)Supercharged (633 reputation)Supercharged (633 reputation)Supercharged (633 reputation)Supercharged (633 reputation)Supercharged (633 reputation)Supercharged (633 reputation)Supercharged (633 reputation)Supercharged (633 reputation)
Posts: 266, Visits: 3.5K
Yes, except I'm using a port on the front of the carb with a PCV in line
Tim Quinn
Posted 6 Years Ago
Do we need to use a inline PCV ?????????
Tim Quinn
Posted 6 Years Ago
I noticed that on the head on the left, that there is a tube running to a drain hole at the top of the head. There is not tube like this on the head of my car.
Could this be the problem????
Get back,
Thanks,
Tim in Florida
Posted 6 Years Ago
Yes. If left off intentionally/unintentionally or if  the rocker arm assembly was pressurized with no relief, the oil supply can pool in the head surface and overwhelm the valve seals. The left heads usually sees more supply.
http://forums.y-blocksforever.com/uploads/images/cb6b4c12-65ca-431f-a1e7-349c.jpg
http://forums.y-blocksforever.com/uploads/images/8cbe52ac-4a7b-4ec2-b9e5-3f3b.jpg
Tim Quinn
Posted 6 Years Ago
That's it !!!!
That tube is missing from the left bank for sure !!
Big time thanks.
NOW, where do I find these tubes ?
Any hints ?
Let me know,
Tim in Florida
AGAIN, BIG TIME THANKS
darrell
Posted 6 Years Ago
Posts: 455, Visits: 22.2K
is there one on the other side.some people block these of.check to see if yours is blocked of which you can see just by looking.if thats the case start the engine and see how much oil is running in the heads.it should not run out with the rocker covers of.
Posted 6 Years Ago
http://forums.y-blocksforever.com/uploads/images/d9cbe62f-e356-4095-ba54-6031.jpg
TUBE - B5A 6588-A
SUPT - EBU 6575-A
Talk to the machinist first and see if he left them out for some reason. If he didn't, GOOGLE the PN's exactly as shown and you should come across them.
Posted 6 Years Ago
Last Active: 3 Weeks Ago
If You do need One pretty sure Carl would have a used One. He seems to have just about everything Someone is looking for. Helped Me out when I needed a missing Oil Slinger recently.
darrell
Posted 6 Years Ago
these must be pressurized rockers.there has to be bolts in those holes otherwise the shafts would turn as thats what holds them in place.
