Last Active: 1 hour ago
Visits: 498.2K
What are the differences between the TBird 55/56 front brake shoes and the TBird 57 brake shoes. I see listing this way. Size? I don t have any reference to see if the size of the 57 shoes are different. I know 56's are 2 1/4 x 11
57RancheroJim
Visits: 112.0K
According to my 57 shop manual they are 11", but they list the primary shoe as 2" and secondary as 2 1/2". That seems strange to me but I'm not a Bird expert.
Pete 55Tbird
Visits: 93.2K
Paul, the 55/56 Tbird used the Ford Station Wagon brakes front and rear. The 57 Tbird used the Ford 9 inch rear end rather than the Dana 44, used on the 55/56 Tbird. Start there Pete
Visits: 498.2K
Pete thanks - but the front's are the ones that show a difference. 57RancheroJim (11/30/2018)
Visits: 498.2K
Thanks Jim - I know it sounds funny, but maybe that's the difference. The primary shoe on the 56 shows 1 3/4 (secondary 2 1/4). Most sets today have the 2 1/4 for both primary and secondary based on the two sets that I have here 57RancheroJim (11/30/2018)
Pete 55Tbird
Visits: 93.2K
Paul, OK look up front brakes 1955/56 Ford Station Wagon/Courier on any parts website. A word of caution about turning the Drums. I don`t know just when the MAX OVERSIZE was part of the Drum but .030 is a good LIMIT or distortion/warping can occur when brakes are used and drums get HOT. Pete
Paul, if this is not the issue can you explain IN A DIFFERENT way what the issue is?
57RancheroJim
Visits: 112.0K
I'm only guessing but the 57 is probably heavier then the 55-56 hence the wider shoes?
Sandbird
Visits: 542.7K
Paul, From the '57 TBird Engineering and Specifications Manual from CTCI the front secondary lining is 11" x 2 1/2" and the front primary is 11" x 2".
Pete 55Tbird
Visits: 93.2K
From the 1949 to 1959 Ford Parts Manual front brake shoe and lining S/D, S/W B6A 2001 - B My magic decoder reads this as S = Tbird W = Station Wagon D = Courier delivery 2-AF 2018 -Y Primary 2-AF 2019 -U Secondary You got a computer, get to work. Pete
Visits: 498.2K
Seems to be a lot of different answers here but I appreciate everyone's contribution. Some say 2 1/4, some 2 1/2 on the 57. secondary. I don't have 57 (ONLY A 56) shop manual so that is why I posed the question. I have a set of brakes shoes for an early TBird and both primary and secondary shoes are 2 1/4 (primary linings a little shorter as usual) that I want to sell and don't want to misrepresent them.
As far as the different brake setup, Kultulz, my 56 has no such items and are just like any later Ford. I have changed them twice so I know whats under the drum. If I remember correctly, I bought the shoes from a Tbird parts supplier
Sandbird - this is different than what the shop manual says per RancheroJim but may be correct as CASCO's listing for drums show the 57 as different
I thought that my question was clear enough - what is the difference between 55/56 and 57 front brake shoes
