Visits: 13.9K
Visits: 13.9K
No freeze plugs all early heads have freeze plugs, also G stamped next to the cast EBU
The date code looks like May 3 1956. I'm sure replacement heads were cast. Maybe it's simply a replacement. The ports, valve size and chambers look right for 239. Sometime toward the middle of '56 production, heads began to be cast without core plugs.
Visits: 22.3K
must be a replacement.cant get a good look at the sparkplug holes are they still the small plugs.
Visits: 13.9K
What about the G stamped into the head?
Maybe it just indicates a revision, since there are some differences from the original EBU castings. What size are the spark plug threads?
Visits: 13.9K
Large
Visits: 22.3K
interesting changes no core plugs and went to the later plugs.just when you thing theres nothing left to see in y blocks along comes something new.i dodnt thing ill live lone enough to see it all.
Cliff (11/24/2018)
What about the G stamped into the head? Keep in mind that the 239 engine was used as the base V8 engine in the Ford pickups after 1954. EBU-G heads are not to be confused with ECZ-G heads. When someone says they have ‘G’ heads, it needs to be clarified which ‘G’ head.
