Cylinder Heads - EBU-G castings
http://forums.y-blocksforever.com/Topic141673.aspx
By Cliff - 8 Years Ago
Anybody know what these are? in looking through my stock pile I found these, early heads no freeze plugs, stamped with a G after the cast EBU.
http://forums.y-blocksforever.com/uploads/images/9b007bf2-a207-4ebf-842b-835a.jpg
http://forums.y-blocksforever.com/uploads/images/10d97003-8338-4043-b98c-c5af.jpg
http://forums.y-blocksforever.com/uploads/images/8357c8bd-2a93-45b4-85a7-0d41.jpg
http://forums.y-blocksforever.com/uploads/images/ae1d6825-7988-465e-bf13-1726.jpg
http://forums.y-blocksforever.com/uploads/images/e4c98da3-afe6-4eca-acf5-3ae4.jpg
239
http://www.ford-y-block.com/cylinderheadchart.htm
No freeze plugs all early heads have freeze plugs, also G stamped next to the cast EBU
The date code looks like May 3 1956.  I'm sure replacement heads were cast.  Maybe it's simply a replacement.  The ports, valve size and chambers look right for 239.  Sometime toward the middle of '56 production, heads began to be cast without core plugs.
By darrell - 8 Years Ago
must be a replacement.cant get a good look at the sparkplug holes are they still the small plugs.
What about the G stamped into the head?
Maybe it just indicates a revision, since there are some differences from the original EBU castings.  What size are the spark plug threads?
Large
interesting changes no core plugs and went to the later plugs.just when you thing theres nothing left to see in y blocks along comes something new.i dodnt thing ill live lone enough to see it all.
By Ted - 8 Years Ago
Cliff (11/24/2018)
Keep in mind that the 239 engine was used as the base V8 engine in the Ford pickups after 1954.  EBU-G heads are not to be confused with ECZ-G heads.  When someone says they have ‘G’ heads, it needs to be clarified which ‘G’ head.
the ebu 239 was a 54 only engine with the large cam.the truck was ebv and used a small cam.the mixup came when they used the ebu engines in early 54 trucks by mid year they no longer used it.the ebu is the only real oddball y block.all others use the small cam and same head gaskets.
These heads take the early head gasket, but have 18 mm spark plugs, also the chambers do not over hang the cylinder (well a little at the sides with a 3.860 bore) also has the late exhaust port, I think i'm going to sonic check the insides of the ports for fun.
I took a look inside, these will take a 1957 size port without hitting water, these maybe a better head to start with, better chamber to work with.http://forums.y-blocksforever.com/uploads/images/36410eb4-3602-4fab-8132-7feb.jpghttp://forums.y-blocksforever.com/uploads/images/636be1e7-d126-4231-a852-a5dd.jpg
As long as it wasn't the last one on earth Wink
I wonder how that actually compares to a '54 EBU head.  If the part of the mold for the water jacket was '56, like many other features, it very well may have more material there.
