Visits: 22.3K
the ebu 239 was a 54 only engine with the large cam.the truck was ebv and used a small cam.the mixup came when they used the ebu engines in early 54 trucks by mid year they no longer used it.the ebu is the only real oddball y block.all others use the small cam and same head gaskets.
Last Active: 4 hours ago
Visits: 14.0K
These heads take the early head gasket, but have 18 mm spark plugs, also the chambers do not over hang the cylinder (well a little at the sides with a 3.860 bore) also has the late exhaust port, I think i'm going to sonic check the insides of the ports for fun.
Visits: 14.0K
I took a look inside, these will take a 1957 size port without hitting water, these maybe a better head to start with, better chamber to work with.
As long as it wasn't the last one on earth  I wonder how that actually compares to a '54 EBU head. If the part of the mold for the water jacket was '56, like many other features, it very well may have more material there.
