Help Harmonic Balance Puller
Posted By texas55 7 Years Ago
texas55
Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)
Posts: 12, Visits: 1.1K
Hello Folks,
Need help to figure out how to pull my Harmonic Balancer off.  Need to get to my internal parts on my cover, think I have a problem inside which prevents my fuel pump from operating properly.  Tried numerous pullers from the local auto parts store.  Want to prevent damaging the pulley.  Any help would be greatly appreciated.  I'll attach a picture hopefully you guys can help me out.
Leehttp://forums.y-blocksforever.com/uploads/images/caba6935-667a-4a46-8120-5e7e.jpg
Posts: 6.1K, Visits: 442.8K
T-Bird?
texas55
Yes Sir,
 Bought this t bird many years ago, been slowly bringing it to life.  Not original damper I believe.
Lee
Last Active: 4 Weeks Ago
http://forums.y-blocksforever.com/uploads/images/cbaefa7a-272e-4c24-bcb3-e214.jpg
The T-Bird uses the Hook Type Damper Puller as opposed to the Flat Style used on Passenger Cars, See the Attached Picture from Shop Manual. It looks like the One on Yours so it may be Original. On T-Birds the double Sheave Damper was Standard.
http://forums.y-blocksforever.com/uploads/images/ba9ae157-21d8-47e4-9323-5934.jpg
Last Active: 11 hours ago
Your pictured damper looks like a Thunderbird unit.
Here’s the link to a past thread regarding damper pullers for the Thunderbird dampers.
http://forums.y-blocksforever.com/FindPost50258.aspx
Ted (11/11/2018)
The One You  were given from the Ford Dealer looks like the One in the Picture from Shop Manual so I would think it is the One originally designed by Ford for this Application.
texas55
Thank you all.  Really appreciate the help.
Lee
Posts: 1.2K, Visits: 285.6K
I recently bought a TBird balancer puller tool from Casco.  Worked like a charm. While you are at it, buy the installation tool as well.  http://www.classictbird.com/
Posts: 4.6K, Visits: 38.4K
I have the Casco puller and installer tools I bought and cant use. I'll take $70 plus shipping for them.
I used one from Harbor Freight. After removing the center bolt it almost fell off and it was original to the engine. Remember to lube the screw on your puller. good luck
