292 & auto trans number #16254
Posted By jw375 7 Years Ago
jw375
Turbocharged (61 reputation)Turbocharged (61 reputation)Turbocharged (61 reputation)Turbocharged (61 reputation)Turbocharged (61 reputation)Turbocharged (61 reputation)Turbocharged (61 reputation)Turbocharged (61 reputation)Turbocharged (61 reputation)
Posts: 22, Visits: 12.3K
Ok sports fans I found a 292 with a auto trans, came out of a truck maybe.. The number on the trans is 16254 , must be missing numbers ...sounds like 54 would be 1954..
any opinions ..   I can get a good price on it so it can be rebuild .. any idea of cost.. ?
See i do try to keep the history alive ..  please feel free to email me
If the bellhousing has truck mounting ears then it is for a truck.  If it does not have those, then it is for a car.
I don't know how to identify which transmission it is.  If the engine displacement is any concern then use the information here, http://www.ford-y-block.com/technical.htm to identify it.  Don't take the seller's word for it.
Rono
Posts: 1.3K, Visits: 80.0K
I thought as a rule of thumb, no trucks with a Y Block came stock with an automatic. Is that true?
Last Active: 4 hours ago
Posts: 3.7K, Visits: 323.2K
Yes, trucks came with automatics.  Also, if the engine in question is really a 292, then the transmission is probably not a '54.  A 54 truck would have had a 239.  Of course, a lot of parts swapping may have been done over the years.  Interchangeability of parts was a good feature of Y Blocks.
Last Active: 6 days ago
quote]jw375 (7/26/2018)
[/quote]
There should be a Ford ID Tag riveted to the Case. U might have to clean it off to get the Info on it. Letters and #'s. Is it Air cooled or does it have Connectors to hook up cooling Lines?
2721955meteor
Posts: 927, Visits: 190.0K
the 56 i had with a auto trans had a remote cooler that had engine watter circulating ,also had a short tail shaft. trans had truck style mount ears on bell housing..other than the case could be no more to overhaul than any other 3speed auto .this was a canadian built f100
