pulley alignment
Posted By stuey 7 Years Ago
stuey
Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)
Posts: 443, Visits: 3.8K
Hi Dave  thanks for reply. Much appreciated. I'll keep at it till I get within 1/2 a degree.   Ho  Hum  The alternator is the only one at 0 deg. relative to crank pulley and that took 5 attempts welding and re-drilling the brackets.
stuey
Dave C
Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)
Posts: 101, Visits: 31.2K
For me it is very critical. High RPM could throw the belt. I use a straight edge across both pulley's to get them straight in the horizontal and a angle finder for vertical.
Machine spacers as needed till it's right.
Works for me.
Dave
stuey
Hi all
Just curious. How critical are you regards pulley alignment? The belt manufacturers quote 1/2 degree and three planes. There are limited means of adjustment.
Fore and aft with shims/spacers is one. But I'm finding my water pump is 1 1/2 degrees vertically out compared to the crank pulley. This is throwing off the power steering pump which is hung off the water pump
Without re-machining the pump the only way I can think of is to pad out the gasket .
stuey
