By stuey - 7 Years Ago
Hi all Just curious. How critical are you regards pulley alignment? The belt manufacturers quote 1/2 degree and three planes. There are limited means of adjustment. Fore and aft with shims/spacers is one. But I'm finding my water pump is 1 1/2 degrees vertically out compared to the crank pulley. This is throwing off the power steering pump which is hung off the water pump Without re-machining the pump the only way I can think of is to pad out the gasket . stuey
By Dave C - 7 Years Ago
For me it is very critical. High RPM could throw the belt. I use a straight edge across both pulley's to get them straight in the horizontal and a angle finder for vertical. Machine spacers as needed till it's right. Works for me.
Dave
Hi Dave thanks for reply. Much appreciated. I'll keep at it till I get within 1/2 a degree. Ho Hum The alternator is the only one at 0 deg. relative to crank pulley and that took 5 attempts welding and re-drilling the brackets. stuey
