1954 CAPRI
Posted By pinchsplat 8 Years Ago
pinchsplat
General Posted 8 Years Ago
Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)
Posts: 4, Visits: 6
ANYONE RECOMMEND A SUITABLE CARBURETOR CONVERSION,4BBL, TO
HELP ALLEVIATE HARD STARTING AFTER A 7, OR MORE DAYS,SITTING.OTHERWISE
VEHICLE RUNS AND PERFORMS BEAUTIFULLY.
Last Active: 14 minutes ago
Posts: 4.6K, Visits: 38.8K
An electric in line fuel pump to fill the bowls prior to starting will cure this.
pinchsplat
Posts: 4, Visits: 6
good advice Moonshadow,however that has already been tee`d in,along with a Pertronic system,
carb has been gone thru,new Battery,cables,etc.runs great and re-starts easily after initial cold start.
Do you let the pump run a while to fill the carb bowls?
Is the choke closing properly & the pull off kicking open as it starts?. For instance, some carbs such as Quadrajets can take 4 or 5 pumps to the floor after sitting for a substantial perod in the cold, before they will start..
pinchsplat
Posts: 4, Visits: 6
A few more pedal pumps may be necessary,and yes the choke closes  when cold,and good
choke break when started.Thanks for the tips guys.
Mine usually requires a bit different technique after several days even with a modern carb and electric pump.  It seems like the accelerator pump also has to fill and doesn't really do it until I give it a couple pumps of the pedal.  Otherwise, it typically starts with just a bump of the starter.
pinchsplat
Posts: 4, Visits: 6
thanks charlie,good to know. seems I would be wasting time and money with carb conversion/update.
56_Fairlane
Posts: 575, Visits: 14.6K
I just take the air cleaner lid off mine and pour a little gas down the carb if my Fairlane has sat a while. I'll even use a little 2-stroke mix if it sat more than a month. I don't pump it nor even touch the pedal when cranking it. I'll just hit the pedal once before turning the key to set the choke after pouring the gas. It starts almost instantly but stumbles just a little before the carb fills and then smooths out. Once it's idling the air cleaner goes back on.
~DJ~ AKA "Bleach"
