By pinchsplat - 8 Years Ago
ANYONE RECOMMEND A SUITABLE CARBURETOR CONVERSION,4BBL, TO HELP ALLEVIATE HARD STARTING AFTER A 7, OR MORE DAYS,SITTING.OTHERWISE VEHICLE RUNS AND PERFORMS BEAUTIFULLY.
By MoonShadow - 8 Years Ago
An electric in line fuel pump to fill the bowls prior to starting will cure this.
good advice Moonshadow,however that has already been tee`d in,along with a Pertronic system, carb has been gone thru,new Battery,cables,etc.runs great and re-starts easily after initial cold start.
Do you let the pump run a while to fill the carb bowls?
By PF Arcand - 8 Years Ago
Is the choke closing properly & the pull off kicking open as it starts?. For instance, some carbs such as Quadrajets can take 4 or 5 pumps to the floor after sitting for a substantial perod in the cold, before they will start..
A few more pedal pumps may be necessary,and yes the choke closes when cold,and good choke break when started.Thanks for the tips guys.
Mine usually requires a bit different technique after several days even with a modern carb and electric pump. It seems like the accelerator pump also has to fill and doesn't really do it until I give it a couple pumps of the pedal. Otherwise, it typically starts with just a bump of the starter.
thanks charlie,good to know. seems I would be wasting time and money with carb conversion/update.
By 56_Fairlane - 8 Years Ago
I just take the air cleaner lid off mine and pour a little gas down the carb if my Fairlane has sat a while. I'll even use a little 2-stroke mix if it sat more than a month. I don't pump it nor even touch the pedal when cranking it. I'll just hit the pedal once before turning the key to set the choke after pouring the gas. It starts almost instantly but stumbles just a little before the carb fills and then smooths out. Once it's idling the air cleaner goes back on.
