Thermostat brand
Posted By 62bigwindow 7 Years Ago
62bigwindow
Posts: 884, Visits: 14.3K
What brand of thermostat are have you had good luck with? I've been through 2 in a few months. Both have broke and luckily stuck open. The first was a Shaw and the second was a high flow Mallory,if I'm remembering correctly.
Durham Missouri
Bob Gardner
Posts: 118, Visits: 2.0K
I installed a Murray Temp Control (part # 3478) in my Y block.  This thermostat is for a 318 MOPAR and is rated at 180 degrees.  I needed this temperature to have the EFI work properly.  A part search on one of the online companies like Rock Auto or Summit you should be able to find a lower temperature unit for the 318 MOPAR.
62bigwindow
I'm running a 190° now. Just can't seem to find one that will last. Thanks for the recommendation. I'll look at them.
Durham Missouri
Posts: 3.6K, Visits: 497.7K
Currently I'm running a Moto Rad 170 degree  (part # 321-70) in  my Tbird.  I run a NAPA # 6 (170 deg.) in my 54 Ford 312.  No problems.
Posts: 6.1K, Visits: 442.8K
Milodon.  It's a made in USA Robert Shaw.
