By 62bigwindow - 7 Years Ago
What brand of thermostat are have you had good luck with? I've been through 2 in a few months. Both have broke and luckily stuck open. The first was a Shaw and the second was a high flow Mallory,if I'm remembering correctly.
By Bob Gardner - 7 Years Ago
I installed a Murray Temp Control (part # 3478) in my Y block. This thermostat is for a 318 MOPAR and is rated at 180 degrees. I needed this temperature to have the EFI work properly. A part search on one of the online companies like Rock Auto or Summit you should be able to find a lower temperature unit for the 318 MOPAR.
I'm running a 190° now. Just can't seem to find one that will last. Thanks for the recommendation. I'll look at them.
By paul2748 - 7 Years Ago
Currently I'm running a Moto Rad 170 degree (part # 321-70) in my Tbird. I run a NAPA # 6 (170 deg.) in my 54 Ford 312. No problems.
Milodon. It's a made in USA Robert Shaw.
