Eric
Visits: 261
I have a 1956 ford fairlane differential with 3.90 ratio. Would like to go to 2.90 or 3.0 What would be the easiest option? Is there something else i can bolt right up to same housing? It has 17 spline axle shafts. Thanks
Dobie
Visits: 22.0K
The easiest option would be to find a good diff from a mid 50s Ford that had an automatic in front of it. Those are around 3.30:1 and bolt in. A good modern diff would be the 8" from a Ranger or Exploder however the pumpkin is offset to the left so you'd need to get another right hand axle & tube to center it. Those come in a variety of ratios and custom ring & pinion sets are available if none of the stock ratios suit your needs.
Joe-JDC
Last Active: 6 minutes ago
Visits: 23.3K
Dobie (12/17/2017)
The easiest option would be to find a good diff from a mid 50s Ford that had an automatic in front of it. Those are around 3.30:1 and bolt in. A good modern diff would be the 8" from a Ranger or Exploder however the pumpkin is offset to the left so you'd need to get another right hand axle & tube to center it. Those come in a variety of ratios and custom ring & pinion sets are available if none of the stock ratios suit your needs. The Ranger and Explorer differentials are 8.8", not 8". They are completely different, the 8" is a removable chunk like the Ford 9", but the 8.8" has a rear cover, and the gears must be set up in the housing. Joe-JDC
Last Active: 5 hours ago
Visits: 39.4K
Eric, where are you located? It helps to put city and state in your tag line. I have a couple spare pumpkins for the 56 Ford stock rear end. I can check the gear ratios if you like and would be willing to sell at least one. Shipping may be a problem depending on where you live.
Eric
Visits: 261
Moonshadow,
Thankyou for the response. I live in Fond Du Lac WI. I would be interested in what you have if it is in the 2.90 to 3.00 or so ratio. Photos would be great also to confirm it is correct. I would really only need the ring and pinion I believe. Let me know . Thankyou, Eric
Last Active: 1 hour ago
Visits: 498.2K
. There is nothing that is a bolt in in the ratios you are looking for. The nearest would be an automatic rear which is around 3.30. Other than that, an early (57-58) rear would bolt in but you would have to find a set of gears in the ratios you are looking for. Usually, they are available. Eric (12/17/2017)
Visits: 39.4K
They are take outs from a 56 probably 3:30's. I replaced mine with a 3:80 posi unit. Found the Detroit Gear original 56 Posi unit on EBAY several years ago. Will check tomorrow.
Lou
Last Active: 5 Months Ago
Visits: 8.4K
56 auto rear gear is 3.22, all others that bolt in (49\/55) are 3.30. If you use a 49/55 you have to use 49/55 axles. What engine and trans are you running.?
Dave V
Last Active: 13 hours ago
Visits: 41.7K
Lou is correct. 56 automatics used a 3:22 gear
SE Wis
Eric
Visits: 261
Lou
I am running a 351c with fmx 3 spd auto. Turning about 3700rpm at 60mph with 3.90 rear.
