1956 ford fairlane differential
Posted By Eric 9 Years Ago
The gentleman who built my 56 used a 55 3.30 rear. Since I just went to a true 3 speed automatic my next project is to replace the entire rear end. From what I've read a 65-6 Mustang V8 is very close to a bolt in with the total width within 1/4-1/2" and what I've read and the spring perch being very close. Most I've found have 2.80 or 3.00 gears. I've found them complete with e-brake cables still on. Prices vary but after the new year it's my next purchase. Good luck.
RB
Posts: 662, Visits: 16.7K
Eric  I have a 56 rear I just pulled out  3.22 ,good drums, nice rust free one... Free for the taking.. Stevens point
Posts: 4.6K, Visits: 39.5K
They went to the 9" in 57 so they pumpkin will not bolt in. The entire 57 rear axle is a close fit though but driveshaft and U-Joint mods are required.
Eric
Posts: 7, Visits: 261
Thankyou for the response! Do you know what model 57/58 would bolt in?
Eric
Lou
I am running a 351c with fmx 3 spd auto. Turning about 3700rpm at 60mph with 3.90 rear.
Dave V
Supercharged (465 reputation)Supercharged (465 reputation)Supercharged (465 reputation)Supercharged (465 reputation)Supercharged (465 reputation)Supercharged (465 reputation)Supercharged (465 reputation)Supercharged (465 reputation)Supercharged (465 reputation)
Posts: 237, Visits: 41.7K
Lou is correct. 56 automatics used a 3:22 gear
SE Wis
Lou
Last Active: 6 Months Ago
Posts: 564, Visits: 8.4K
56 auto rear gear is 3.22, all others that bolt in (49\/55) are 3.30. If you use a 49/55 you have to use 49/55 axles.
What engine and trans are you running.?
They are take outs from a 56 probably 3:30's. I replaced mine with a 3:80 posi unit. Found the Detroit Gear original 56 Posi unit on EBAY several years ago. Will check tomorrow.
Posts: 3.7K, Visits: 498.3K
.  There is nothing that is a bolt in in the ratios you are looking for.  The nearest would be an automatic rear which is around 3.30.  Other than that, an early (57-58) rear would bolt in but you would have to find a set of gears in the ratios you are looking for.  Usually, they are available.
Eric (12/17/2017)
I have a 1956 ford fairlane differential with 3.90 ratio. Would like to go to 2.90 or 3.0  What would be the easiest option? Is there something else i can bolt right up to same housing? It has 17 spline axle shafts. Thanks
Eric
Moonshadow,
Thankyou for the response. I live in Fond Du Lac WI. I would be interested in what you have if it is in the 2.90 to 3.00 or so ratio. Photos would be great also to confirm it is correct. I would really only need the ring and pinion I believe. Let me know . Thankyou,
Eric
