1957 and up distributors
Posted By monarch 9 Years Ago
Tedster
Posts: 513, Visits: 153.3K
Jeeze Louise. I "assumed" since I bought a remann Cardone a couple years ago I was OK.
Not. The distributor driven gear in these counterfeits will only engage on the bottom half, or less judging by the wear pattern.
So I'm looking at rebuilding one of the cores I have laying around. DC assures me they have the old, "fat comma" style advance weights in stock, though I can't find them on their site. B7A-12188-A The problem with these, is the slot pins, though made of hardened steel, get grooves worn into them.
The distributor cam itself though, the slots also show some wear. Probably be OK, but if anyone has access to the part # for these that would be great, I believe this was actually an Autolite distributor. 13L is stock I believe.
Posts: 3.8K, Visits: 33.4K
Kahuna (6/2/2018)
Is it possible to purchase just the vacuum advance units for an original 57 & up distributor?
Jim
I just purchased an original 1957 Distributor. You might want to read my Post regarding this Type Vacuum Advance.. You can buy the Advance  without the Spacers/Springs from amongst others Macs. If I read the Information from Steve "Greenbird56" correctly you can use the later Vacuum Advance if You also change the Breaker Plate to later Style.
Last Active: 1 hour ago
Posts: 2.0K, Visits: 306.7K
Yes.
The 57/58 is unique as is 59/ (matches breaker plate style)
Kahuna
Posts: 471, Visits: 2.4K
Jim
Posts: 3.7K, Visits: 498.3K
Trucks??  In 1963 the only Y Blocks were the trucks.
Tedster (5/31/2018)
Went through my stash of parts and have two rebuildable cores, is there an application chart somewhere listing what these came out of exactly?
C3TF A 12127 2MB
C3TF K 12127 4FC
Tedster (5/31/2018)
KULTULZ (5/31/2018)[
2MB and 4FC are date codes.
Hm, I thought C3 was the date code, and T of course means truck etc., the shop manual sez K suffix designates 292 V8 but is silent on the rest.
C3 would refer to the 1963 model year the part was released for assembly. The other characters if stamped is the actual assembly date of the dist assy..
If you see a Casting I.D. No. on the distributor housing with a Basic PN 12143, that refers to the actual bowl casting I.D. and any Cast Date Code would be the casting date of the bowl.
The MPC would show more concise/up to date and detailed info (service upgrades/superscessions) over a Shop Manual. The Shop Manual will give you detailed service info (curves for instance) (along with Service Letters/TSB's) whereas the MPC will not.
Hope that came out understandable...
Tedster
Tedster (5/31/2018)
C3TF A 12127 2MB
C3TF K 12127 4FC
Yes, but the ID Chart will be found in the TRUCK MPC for that period. Both are truck applications.
Tedster
C3TF A 12127 2MB
C3TF K 12127 4FC
Tedster (5/29/2018)
The only caveat there, the internal rubber diaphragm is vintage 1957 as well, and may be dried out by now and crispy. Won't last long in service, maybe.
Thanks. The Seller assures Me it is working now. They are available in the event it does stop working. I am just happy to have found what looks like a very good original Distributor so I can get on with my Conversion.
