motor surging
Posted By Bobby O 55 8 Years Ago
Lord Gaga
Posts: 464, Visits: 183.3K
Sounds fuel related. A lean condition possibly. I would check everything from the tank pick-up  up to and including the carb.
"FREE SAMPLE"
Bobby O 55
Supercharged (207 reputation)Supercharged (207 reputation)Supercharged (207 reputation)Supercharged (207 reputation)Supercharged (207 reputation)Supercharged (207 reputation)Supercharged (207 reputation)Supercharged (207 reputation)Supercharged (207 reputation)
Last Active: 4 Months Ago
Posts: 72, Visits: 385
I bought the coil at the same time I bought the distributor. It came as a package.
Talkwrench
Posts: 898, Visits: 23.2K
Are you using the correct ohms rated coil to match ?
This does sound like a lean condition from your description..
Bobby O 55
I have a Mallory ignition for a Y Block.
62bigwindow
Posts: 884, Visits: 14.3K
What conversion kit did you use?
Durham Missouri
Posts: 3.7K, Visits: 497.8K
Long shot I guess - but a 8 volts on a 6 volt electronic ignition?????
56_Fairlane
Last Active: 10 Months Ago
Posts: 575, Visits: 14.6K
I still think it's something carb related. What kind of carb is it? Have you checked the fuel filter?
~DJ~ AKA "Bleach"
Bobby O 55
It's not a teapot it's a 2 barrel. It's a rebuilt. I put it in about 2yrs ago, ran great. It just started this surging thing about three weeks ago.
Bobby O 55
It's a rebuilt I put in last year.
56_Fairlane
I'm thinking it could be a sticking needle valve or low float level in the carb. I've had something like this happen on another carbureted car I once owned and it was a sticky worn needle.
~DJ~ AKA "Bleach"
