Y-Block transmission adapters
Posted By 50mercfan 8 Years Ago
carl
Posts: 1.2K, Visits: 20.6K
I have two,but they are not cheap  Carl
Here's one for C4
http://www.ford-y-block.com/c4adapt.htm
Kahuna
Posts: 471, Visits: 2.4K
Carl
How hard is it to find one of those bell housings?
Jim
carl
You can also use a C1 AP 7976 aluminum bellhousing,a cruse o matic ,ford o matic and FMX will bolt up to this ,no adapter needed  Carl
Posts: 4.6K, Visits: 38.5K
This is the company Hotdoger1 was talking about. I used them and was quite happy. Been running for many years. Lokar also sells a column shift adapter that worked for me.
http://www.transmissionadapters.com/ford_y_block.htm
hotdoger1
Normally aspirated (45 reputation)Normally aspirated (45 reputation)Normally aspirated (45 reputation)Normally aspirated (45 reputation)Normally aspirated (45 reputation)Normally aspirated (45 reputation)Normally aspirated (45 reputation)Normally aspirated (45 reputation)Normally aspirated (45 reputation)
Posts: 14, Visits: 3.4K
I did the swap to an aod got adapter at brandinson in  Minnesota. don't know if it spelled right.it is a bolt in deal. have to make your own shifter and get a locar cable. I drove it 2000 miles last year on a 378 rear but I going to put in a 355 this year. you will like it
Link from here to John Mummert's site. I believe he has an adaptor to C-4s. Also has an adaptor to T-5 std transmissions.
50mercfan
Normally aspirated (47 reputation)Normally aspirated (47 reputation)Normally aspirated (47 reputation)Normally aspirated (47 reputation)Normally aspirated (47 reputation)Normally aspirated (47 reputation)Normally aspirated (47 reputation)Normally aspirated (47 reputation)Normally aspirated (47 reputation)
Posts: 14, Visits: 78
that is helpful,im afraid i was clear enough in my original post, im swapping from a 3 speed manual to a later model automatic.
50mercfan.  Welcome to the site.
Click the link below that will connect you to an article that is on the 'Tech Articles' section of this web site.  I've had no experience making the swap of a C-4 for a Fordomatic, but this article seems like it provides quite a bit of information.
http://www.y-blocksforever.com/tech/html/c4conv.html
Hope this helps!   Smile
Posts: 3.7K, Visits: 497.8K
I put a C4 behind the 312 in ,my 56 Bird.  Used a Flat-O-Matic kit.  Went very well.  Used the stock 56 kickdown, but had to modify it a little (extended it).
Very happy with the result.  I was not interested in a O/D even though I drive it long distances but if you want an O/D then  the AOD is probably the best way to go.
