Visits: 168
I have everything I need to bolt a T10 4 speed to my 292 project except the pressure plate. Contacted a brake and clutch outlet and they were no help. Any suggestions where to find the passenger car clutch? Thanks.
Visits: 31.8K
I have seen pressure plates on ebay
Visits: 137.8K
Any auto parts store. Just make sure you have the right spline and disk diamater. 292 is usually 10". 312 is 11"
Last Active: 13 hours ago
Visits: 41.4K
I have an almost new 10" that I removed when I went to an 11". Dave
SE Wis
Visits: 168
My flywheel is drilled for an 11" cover but, hey, I appreciate the offer. My local Napa store had no listing but I see Summit has a kit manufactured By ZOOM only their disc is 23 spline and I need 10. We have another parts store in town so I will give them a shot at it.
Visits: 442.8K
The long 11" bolt pattern is the same for many vehicles. All you need is an 11" clutch that comes with a disc with the right spline. Go to Summit Racing, search for clutch and filter by diameter and spline. Should be loads of options.
Last Active: 4 hours ago
Posts: 3.6K,
Visits: 497.7K
Google Centerforce. They have all kinds of pressure plates and discs. I have one of theirs in my 54 with a 312 and toploader.
Visits: 168
Thanks Charlie. I took a little more time on the Summit page and found what I think will work. Kit MU7350-1 has the 10 spline disc although it does not specifically list the 292 Y-Block. The other kit MU7350-1A has the 23 spline disc and appears to be the same with exception of the disc and lists the Y-Block application. Thinking the "A" designation on the end of the part number applies to the different disc. Any thoughts before I purchase? Thanks all. Dave
Visits: 10.9K
Fort Wayne Clutch will build what you need. 800-258-8243
Dan Kingman Az. 86409
Visits: 442.8K
I think the plate and disc will work. The throwout bearing may not since those are not generally as universal.
