Clutch question.
Posted By Drexel 8 Years Ago
Vic Correnti
Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)
Last Active: 1 hour ago
Posts: 347, Visits: 12.3K
Here is a link that lists cars that use a 11" for the 10 spline, a parts store should be able to get you one.
https://www.summitracing.com/parts/ctf-df559000/applications
57RancheroJim
Posts: 729, Visits: 112.0K
I would be skeptical of that listing at Summit. It says 1 3/8" input shaft, thats a truck trans input size. The T10 should be  1" if I recall correctly.
Vic Correnti
OPPs, that was for a top loader.
YBLOCKEREDH
Supercharged (209 reputation)Supercharged (209 reputation)Supercharged (209 reputation)Supercharged (209 reputation)Supercharged (209 reputation)Supercharged (209 reputation)Supercharged (209 reputation)Supercharged (209 reputation)Supercharged (209 reputation)
Posts: 80, Visits: 47.9K
I got mine from John Mummert...
Gary
slumlord444
Posts: 1.2K, Visits: 137.8K
If you have an 11" my recommendation would be a diaphragm clutch rather than a long type. Less pedal pressure in my experience. Before I went to the large input toploader I had an 11" diaphragm clutch for a 390 Ford Pick Up. Worked great and less pedal pressure than the long clutch I had before.
Lord Gaga
Posts: 464, Visits: 183.3K
I'm running an 11" diaphragm type LuK clutch assembly in my '57 with a T-85 O.D. (10 spline 1 "). It was listed for a '62 406. Light pedal, no slip and reasonably priced.
http://www.luk.de/content.luk.de/en/products/clutch_systems_new/clutch_systems_new.jsp
"FREE SAMPLE"
57RancheroJim
My T85 came out of a 1961 390/401hp and has a 23 spline 1"  input.
Edit: corrected
9310alloy
Turbocharged (65 reputation)Turbocharged (65 reputation)Turbocharged (65 reputation)Turbocharged (65 reputation)Turbocharged (65 reputation)Turbocharged (65 reputation)Turbocharged (65 reputation)Turbocharged (65 reputation)Turbocharged (65 reputation)
Posts: 30, Visits: 183.9K
T 85 maindrives cars (not trucks) in overdrive or straight 3 speeds.... As far as I have seen & rebuilt & according to my B/W factory parts book are all 1" x 23 spline & 1" x 10 spline. Most 1956 & 57 Fords / Mercs were the 1" x 10 spline. 1958 to 62 were 1" x 23 spline. Gear tooth count on maindrives are the same 19t. so they interchange.
Mike
9310alloy
My 1960 T85 OD .. 1" x 23 spline
Last Active: 4 days ago
For a throw out bearing there are many that will fit depending on the style of pressure plate you use. I have many different depths and they all fit the same fork. Pain in the butt, but I bought what I thought was right the first time, put it on the pivot ball, slid on the t.o. bearing and slid in the trans. The end of the fork was not where I wanted it. Took in back apart, bought one with approximately a 3/8" added collar, put all bactogether and it was right where I wanted it for the linkage. Good luck.
