Rex HP headers
Posted By Rowen 9 Years Ago
Last Active: 16 minutes ago
Posts: 4.6K, Visits: 39.4K
Gary, its in the length of the whole unit. Rex's tubes are longer and actually make a fairly deep turn down at the rear. I think the tube layout is a little better too but never compared them side by side.
I don't see anything on Red's website that is even similar to the Rex headers.
You might be thinking of the Red's dual tube headers, which look like a non firing order specific tri-Y design with crimped tubing bends whereas Rex is a 4 into one with mandrel bends and possibly larger diameter tubing.
Rono
Posts: 1.3K, Visits: 80.0K
Charlie;
You are correct. I tried to explain earlier that the "dual tube" Red's Headers for Y Block passenger cars is a 2 into 1 not a 4 into 1 design. Red's doesn't make a set of headers similar to Jerry's or Rex. I have a set on Reds dual tube headers my 56 Customline but would not use them on my supercharged motor.
Rono
speedpro56
Posts: 1.3K, Visits: 9.2K
Went to Rex's sight and sure enough it put up a picture of Red's header up as a comparison and I thought it was Rex's. Guess that's an oops!
-Gary Burnette-
Rowen
Posts: 435, Visits: 29.3K
I ordered a set yesterday. Uncoated as I intend to do a wrap on them. Always thought that looked kool and hopefully will help with the heat as well. I noticed on Rex's web site in the pics of his 56, he made a shield to help with the master cylinder, I think that, in addition to the wrap, will protect my ability to stop. Anyway fellas, as with all the other parts I have been accumulating over the past couple years, I will start a build thread along with reviews and pics of the parts/kits as I install them. Be patient, 14 mos till retirement. I will do some Mech work before then but the "big stuff" re-wiring, engine swap, rear end will have to wait till then.
Rowen
55CV
Woodland, Ca
Joe-JDC
Last Active: 6 hours ago
Posts: 795, Visits: 23.2K
Don't know where you live, but wrapping the header will promote rust very quickly if they are not stainless.  The heat will also deteriorate the tubing from the inside.  I have personal experience with the wrap on my truck, and it was a mess.  The ceramic coating, if available, is worth the extra cost in my opinion.  Joe-JDC
Rowen
Joe, I live in north central cal. With the headers as high in the engine compartment as they are, unlike the truck, and our mostly dry climate, (this year basic monsoons, very unusual), I think I will take my chances on that. It's as much about the "look" as the performance. Ceramic coating just wouldn't "fit". Maybe powder coating?has anyone here gone that route? Still not sure that would look right either. However I do appreciate the words of wisdom and when I see a set wrapped in my area I will be sure to ask them how they have held up. I always appreciate all the great input from this forum. Thanks for all your help.
Rowen
55CV
Woodland, Ca
Rono
I think that the ceramic coating can handle higher heat than the powder coatings can. Check out Jet Hot Coat's website for more info.
Rono
Rowen
Thanks Rono, will do.
Rowen
55CV
Woodland, Ca
I've tried some high temp powder coating and wasn't satisfied with the result. The coatings didn't react well to the exhaust heat cycles. Unless I missed something in my process I wouldn't try it.
