Ball Joint 1956 Ford
Posted By Rudder2fly 8 Years Ago
Rudder2fly
Supercharged (361 reputation)Supercharged (361 reputation)Supercharged (361 reputation)Supercharged (361 reputation)Supercharged (361 reputation)Supercharged (361 reputation)Supercharged (361 reputation)Supercharged (361 reputation)Supercharged (361 reputation)
Posts: 160, Visits: 35.5K
I have the right side suspension dismantled. My question is; on the upper BJ the stud will turn but the ball does not? I suspect that this is not good? Lower ball joint is tight and the ball turns with the stud.
56 VIC  Gene Stoehr Sr.
Last Active: 4 hours ago
Posts: 3.6K, Visits: 497.5K
It sounds like it is broken.  The ball and stud should turn as one but I don't see how the stud would still be attached if it has separated from the ball although it has been awhile since looking at  your type of ball joint.
Rudder2fly
I have the left top BJ out and it is the same as the right side. Stud turns but the ball does not. Makes me wonder if the BJ is really bad? The bottom left BJ is the same as right side.
carl
Posts: 1.2K, Visits: 20.6K
Gene I have a couple nos ball joints,i will check them tomorrow to see if the stud and ball both turn  Carl
Rudder2fly
Thanks Carl.
Last Active: 6 hours ago
Posts: 4.6K, Visits: 37.7K
For some reason I'm finding this discussion confusing. Isn't the stud and ball one assembly?
carl
Rudder2fly (2/21/2017)
Thanks Carl.
Gene I checked a couple and the stud turns but the ball does not turn with it.  Carl
Rudder2fly
Thanks Carl. I will inspect these BJ closely for tightness.  I may holler at you on your NOS BJoints.
aussiebill
Posts: 1.8K, Visits: 11.4K
MoonShadow (2/21/2017)
Me too ! cant be seperate, maybe its the terminolgy.
 Down Under, Australia
Rudder2fly
Hey guys, The stud will turn and the ball does not turn with the stud.
