HEADERS
Posted By zach134 10 Years Ago
zach134
Posted 10 Years Ago
Supercharged (75 reputation)Supercharged (75 reputation)Supercharged (75 reputation)Supercharged (75 reputation)Supercharged (75 reputation)Supercharged (75 reputation)Supercharged (75 reputation)Supercharged (75 reputation)Supercharged (75 reputation)
Posts: 26, Visits: 979
THERE IS NO RUSH TO DO THEM, BUT I MIGHT BE LOOKING FOR A SET OF HEADERS TO USE ON MY 312 Y BLOCK. IT IS IN A 1954 FORD CUSTOMLINE. I THOUGHT ABOUT USING A SET OF THUNDERBIRD HEADERS, BUT IT DOESN'T LOOK LIKE IT WILL FIT ON THE DRIVERS SIDE BECAUSE OF THE PLACEMENT OF THE STEERING BOX. ANY SUGGESTIONS?
THANK YOU,
ZACH
Posted 10 Years Ago
Posts: 1.9K, Visits: 195.0K
I can't speak directly on a '54, but in general bird or truck headers won't work. Trucks use a front motor mount and mounts on the bellhousing, the birds used a similar set up with rods on the sides to prevent the motor from rocking. Cars used side motor mounts, and the bird/truck/rams horns typically won't clear those mounts.
You can get a look at various headers here at Red's site. I had a set of bird headers from him some years back and they were fine. Don't know about current units. Jerry Christensen may still make passenger car headers.
http://reds-headers.net/index.php?main_page=index&cPath=10&sort=20a&filter_id=1
Kahuna
Posted 10 Years Ago
Posts: 471, Visits: 2.4K
I have a set of these. Nice, well made product
http://www.spotlitekustomaccessories.com/store/p8/Ford_Y_Block_Headers.html
Lou
Posted 10 Years Ago
Last Active: 6 Months Ago
Posts: 564, Visits: 8.4K
I have a set of 57 Ford car duel exhaust manifolds if your interested, $200 including shipping. ,  the stainless for $200  looks like a good deal.
62bigwindow
Posted 10 Years Ago
Posts: 884, Visits: 14.3K
Doesn't the 57 and later manifolds flow almost or as good as headers? If that's the case then you will have 0 fitment issues.
Durham Missouri
zach134
Posted 10 Years Ago
THANK YOU EVERYONE FOR THE PLACES TO CHECK. I REALLY DO APPRECIATE IT!!
Genuinerod
Posted 10 Years Ago
Posts: 120, Visits: 33.3K
This company makes headers for your car:http://www.rexhp.com/fuelblocks.html.
62bigwindow
Posted 10 Years Ago
You will need a floor shift for the Rex headers.
Durham Missouri
Posted 10 Years Ago
Since you've got some time, try taking a look at this.
http://forums.y-blocksforever.com/Topic55379.aspx
Some of Mr Eaton's extensive work.
zach134
Posted 10 Years Ago
I CHECKED OUT THE ONES FROM RED'S AND THEY ARE ABOUT THE PRICE RANGE I AM LOOKING FOR. I WOULD LIKE TO RUN LARGER THAN THE 1-3/4 INCH. I WAS LIKING THE DUEL TUBE OR THE 2 INCH TUBE ONES. IT LISTS THE EARLIEST YEAR AS 55...HAS ANYONE GOTTEN THEM TO RUN ON A 54? THEY SAID THEY WON'T WORK, BUT IF ANYONE HAS DONE A MODIFICATION TO FIT, THAT WOULD BE AWESOME.
THANKS AGAIN,
ZACH
