Exhaust test to end all tests?
Posted By Ted 15 Years Ago
Rated 5 stars based on 2 votes.
Posted 15 Years Ago
The exhaust testing results were published in the Nov-Dec 2020 issue of The Y-Block Magazine.  There were some additional tests in that article that were not published in this particular thread.  Because this thread was quite old, the pictures of the various exhausts did not transfer when the website changed servers.  The article as it was published in the YBM has been made available on the Eaton Balancing website.  Here’s the link.
Y-Block Exhaust Testing
Have now completed running an assortment of headers and exhaust systems on the 312 dyno mule.  The mule engine is the same +060 over 312 that’s been used in a variety of other tests.  Specifics for this engine are cast pistons being 0.025” in the hole, ECZ rods, a Crower Monarch camshaft with 238° dur @ 0.050” and 0.459” lift at the valve after lash, an unmodified Mummert intake, and 750cfm Holley on top of a 2” carb spacer.  A set of mildly ported G heads that have been heavily milled brings the compression ratio to 9.6:1 .  Originally being unposted G heads, a pair of posts were installed into each head prior to using them for this series of tests.  With the mill and the porting, these heads were roughly worth 18HP over a set of stock G heads that had a measured static compression ratio of 9.2:1.  With the mild port job, consider these heads a Stage I port job.  There’s over 300 dyno pulls now on the mule engine and the bottom end is still holding up fine other than the rear main has started leaking.  Although the oil from the rear seal is not pouring out, it’s enough to remind you that this engine is now marking its territory.
Mufflers were tested on most of the exhaust combinations and only with the EMC headers did the HP & TQ numbers actually improve with the addition of mufflers.  All other systems did not particularly like the mufflers.  Different inlet sized chambered mufflers were used and which ones being used was determined by the exhaust sizing going into them.  The test range for this series of tests was 2300 to 5500 rpms.  The test range was lowered down to 2300 rpms for the exhaust system testing to get the engine rpms down to that critical lower rpm range that would be seen on a daily driver.  Many of the exhaust systems were tested with varying extension pipe lengths and with & without mufflers.
For simplicity while also providing a quick overview of how each system performed, here’s the charted summary based on the best score for each system that was tested.  Scoring is calculated by adding the average torque and horsepower for the test range, multiplying by 1000 and dividing by the cubic inch.  I’ll add that the best score didn’t necessarily give the best peak HP or TQ values but scoring does gives a better indication of how the ‘as tested’ exhaust system will work in regards to overall performance.  On this chart, the peak HP and peak TQ values are those that belong with the score while the ‘Testing configs” column tells how many variants of that particular exhaust system were actually tested.
Description.
Score
Peak
HP
Peak
TQ
Avg
HP
Avg
TQ
Mufflers
Testing configs
Single exhaust with crossover pipe
1484
239
303
202
276
NO
2
1955/56 Dual Exhaust manifolds
1629
274
327
223
301
NO
4
Reds two tube headers
1635
278
327
224
302
NO
3
1957 Dual Exhaust manifolds
1650
279
330
226
305
NO
4
Fenton cast iron manifolds
1663
282
332
228
308
NO
2
Tri-Y stepped shorty Tbird headers non-firing order specific - GB
1675
294
332
230
309
NO
4
Ram Horns w/2” into 2¼” pipes
1683
283
337
230
312
NO
2
Shorty 1.625” w/box collectors - DC
1693
284
336
231
314
NO
1
Sanderson 1½” T-Bird header w/2” pipes
1724
290
346
236
319
NO
4
Sanderson 1½” T-Bird header w/2¼” pipes
1726
289
346
236
320
NO
4
JC 4 tube car chassis shorty headers
1739
296
347
238
322
NO
6
Tri-Y pickup headers firing order specific-CC
1739
297
347
238
322
NO
5
Sanderson 1½” T-Bird header w/2½” pipes
1751
297
350
240
324
NO
3
Sanderson 1½” Pickup headers w/2½” pipes
1751
300
350
240
324
NO
5
Fenderwell headers 1.75” tubes - MW
1768
306
344
242
327
NO
5
Fenderwell headers 1.625” tubes
1769
308
346
243
327
NO
5
KC 4 tube Maxton Mile 1 5/8” headers
1775
310
351
244
328
NO
4
EMC headers 1.75”/1.875” stepped
1780
310
349
244
329
YES
4
Unfortunately the individual numbers don’t tell the whole story.  The torque curves could be manipulated with different lengths of exhaust pipes or the point in which the muffers were inserted into the system.  I’ll work on some graphs down the road which will better illustrate this.
A big Thank You to all of you that contributed parts or pieces for this exhaust test.  For those of you that sent manifolds or headers for testing, email me and let’s work on getting those pieces back to you.  My email address is under contact info at the following site:  www.eatonbalancing.com
YellowWing
Posted 15 Years Ago
Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)
Posts: 296, Visits: 1.8K
Very interesting Ted. Thank you so much for all your hard work.
1956 Fairlane Victoria (ORREO)
Overlooking Beautiful Rimrock AZ
Posted 15 Years Ago
The greatest improvement comes by simply fitting dual exhaust. That switch alone accounts for nearly half of the total power improvement in the table.
1 1/2" headers are not nearly as bad as I had thought but it does look like 1 5/8" might be generally the best for street performance.
Excellent work, Ted!
At 10.6:1, is it still on pump gas?
crenwelge
Posted 15 Years Ago
Posts: 512, Visits: 1.7K
It's good to see 50 years later that 1958 dual manifolds were an improvement on my 56 Ford over the stock single. Not just in my head. And besides that it sounded a heluva lot better. And I kinda think the girls were impressed by the 2 chrome tips hanging under the bumper
Kenneth
Fredricksburg, Texas
Daniel Jessup
Posted 15 Years Ago
Posts: 2.0K, Visits: 131.2K
Ted - we owe a lot to you on having all this information at our fingertips. Talk about dispelling myths, etc.
How many of you guys vote for Ted being the next author of a "Y block book"? Obviously, one geared towards performance. In my opinion its about time for another one to hit the mainstream, dispell the myths, tell the real story, and give all of the performance features of the mightY engine we love. Wink
Daniel Jessup
Red Lion, Pennsylvania
46yblock
Posted 15 Years Ago
Posts: 1.2K, Visits: 7.8K
"The 21st Century Y-block"  by Ted Eaton.  Sounds Good!
Posted 15 Years Ago
Last Active: 5 hours ago
Posts: 4.6K, Visits: 39.4K
Ted,
Is one of these the headers I sent home with you last year? I think they were pickup style. You had once said you thought they would flow very well. Also how is my project going? Chuck in NH
MS 57 Blackbird
Posted 15 Years Ago
Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)
Last Active: 14 Years Ago
Posts: 21, Visits: 865
Ted,
I would like to concur with the rest of the guys that we are so lucky that we have you doing all the testing for us and I can tell you it has been very beneficial to me and many of us Y-Blockers.  I saw a post a while back that Alan Frakes had made indicating that he might be sending you  a set of the Bird headers that J. Mummert handles.  David Church has a set he will run on his E-Bird that he is restoring and I have a set that will be on my Bird if we can ever get through with the restoration.
Thanks to You Again for all your work.
Larry Boyer
57 Black Bird
bird55
Posted 15 Years Ago
Posts: 1.1K, Visits: 58.8K
Larry, I was never able to send the FPT tbird headers as I was busy driving the car!
Ted, thanks for all your hard work this is great reference and like Charlie said what a interesting thing to see what happens when you lose the crossover pipe and step up to duals!
Pete 55Tbird
Posted 15 Years Ago
Posts: 721, Visits: 93.2K
I would like to thank you for another great job of finding and presenting the facts of the Ford Yblock. Mr. Eaton you have done another outstanding job and I am impressed and grateful for all of your hard work. Pete
