Y block Valve Spring retainers
Posted By Bjmayberry2 10 Years Ago
Bjmayberry2
Posted 10 Years Ago
Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)
Posts: 9, Visits: 8.5K
Anybody know what Valve Spring Retainers to use on our Y Blocks? Seems no one has a listing for the retainers. Tried Perfect Circle, Elgin, Napa & what ever Autozone, Advance Auto & O'Reilly's use too. All have springs, seats, keepers, valves, guides & seals. Some of my other engines have one piece retainers and I think the originals were two pieces. I just need enough of either kind to do two heads.
B.J. Mayberry
Old Guy with Trucks
lowrider
Posted 10 Years Ago
Posts: 479, Visits: 10.9K
I used single valve spring retainers from a sbf on a couple sets of yblock heads. Currently running some light weight single valve spring retainers from Isky on a set of ported G heads on my 57 292.
Posted 10 Years Ago
Last Active: 6 hours ago
I typically go out of my way to replace the two piece valve spring retainers with a single piece retainer design.  I use the Isky retainers for many of the Y engine rebuilds but I’m also using Isky springs on most of those.  John Mummert offers a spring and retainer kit also for the Y engines so you’ll want to check those out also.
Bjmayberry2
Posted 10 Years Ago
The SBF retainers are too large for the ID of the Y Block Springs.
B.J. Mayberry
Old Guy with Trucks
2721955meteor
Posted 10 Years Ago
Posts: 927, Visits: 190.0K
i have a box of old stock new springs from a 312 and they are identical to 292 springs,also retainers(2pice) are the same as earley 289,except 271hp had a 1pc retainer.221sbf had smaller dial. springs. have used several sets of new springs for 289/early 302 s for block they the identical. may be different in canadian build /
