Fan size
Posted By dbird 10 Years Ago
dbird
Posted 10 Years Ago
Posts: 279, Visits: 4.0K
Thanks for all the input, I was already planning on the thermostat and baffle and I think I've figured out my problem with fan size.  I currently have a 18" six blade like this,  http://www.summitracing.com/parts/flx-1018/overview/   , which has very narrow blades.  When you factor in the wider blades of a more conventional fan it might make the effective diameter greater than just measuring across the center of the blade.
Don
Posted 10 Years Ago
Posts: 1.9K, Visits: 195.0K
I've used that style fan, and I don't think they move near the air the factory units do.
jdwilker
Posted 10 Years Ago
Supercharged (114 reputation)Supercharged (114 reputation)Supercharged (114 reputation)Supercharged (114 reputation)Supercharged (114 reputation)Supercharged (114 reputation)Supercharged (114 reputation)Supercharged (114 reputation)Supercharged (114 reputation)
Posts: 37, Visits: 5.1K
Hey Greenbird, what was the diameter of the pulley you used? There seems to be several different variations.
Lou
Posted 10 Years Ago
Last Active: 6 Months Ago
Posts: 564, Visits: 8.4K
You say it runs hot, what do you call hot?
Posted 10 Years Ago
Last Active: 4 days ago
jdwilker. Greenbirds smaller pulley idea saved my 59 Vic's over heat problem at idle and traffic. The one I bought was 6" OD and chrome from a speed shop near me. I rubbed it with a scotch bight and painted it semi gloss black. Ted E said there were many different sizes for different parts of the country. Mine was 7-1/4". Good luck
jdwilker
Posted 10 Years Ago
Thanks for the info. My original pulley is 7.25" and has a depth of 2.5". I've seen several FOMOCO pulleys that are in the range of 6" in diameter but with different depths. I did find one pulley that is 6" by 2.5", but it's a double groove. I'm thinking that won't matter?
GREENBIRD56
Posted 10 Years Ago
Posts: 1.7K, Visits: 102.7K
Sorry for the delay in returning here - as usual work intervened...............
I got the aluminum pulley from CVF and had a friend machine off the back groove to shorten it. Pretty close to the exact required location for the Thunderbird.
http://forums.y-blocksforever.com/uploads/images/39e5c89b-8719-4de7-8f92-9955.jpg
You can also use a steel double groove from a 302 - and cut it off short as well. Looks like the price has gone up on the aluminum version.
http://forums.y-blocksforever.com/uploads/images/243521ef-0fc1-4333-945d-13fa.jpg
As the others have said - I really prefer the mechanical drive fans - and when I fitted the Hayden clutch, slippage cut the available speed by a fair amount. Plus - when I got the waterpump speed up a bit, you could actually see water rushing back into the upper radiator tank (which is what my 289 motor ordinarily did) when the thermostat was full open. Be sure to use one of the wide opening thermostats.
