WHIPPER
Visits: 223
OK, I got it, now I just have to do it, Thanks all of you for info....Whipper Bill
wlj1943
Visits: 780
Like Ted, I too have used Coppercoat for more than 60 years on the gaskets; for the wet bolts either pipe dope or #2 permatex have worked well, as does silicone,all if properly applied. WLJ
Me too. As Ranchero, I never thought of copper coat on anything other than the water passage holes on a head gasket.. Always learning. Thanks
57RancheroJim
Visits: 112.0K
Ted (3/9/2016)
I use CopperCoat on both the timing cover and water pump gaskets. Thats interesting, I have never tried it on other gaskets, just use it on head gaskets, I must try it.
Dobie
Visits: 22.0K
Yes, use the gaskets. Permatex #2 isn't thick enough to serve as a gasket on its own.
57RancheroJim
Visits: 112.0K
Yes, use the gasket. Permatex is a gasket sealant and NOT a replacement for the gasket.
Posts: 7.5K,
Visits: 205.8K
WHIPPER
Visits: 223
OK, thanks fellas, So if I use permatex #2, I coat each housing surface with light coat of sealant. Do I use paper gaskets supplied also? I want to be clear so I don't screw it up.
Talkwrench
Visits: 23.2K
57RancheroJim
Visits: 112.0K
I use Permatex #2 also. I'm old school and probably the last person on the planet that doesn't use silicone or own a cell phone LOL.
