Visits: 2.4K
I'm wondering if any of you fellows know what the transmission gear ratios are in a Ford AOD? Are they all the same? Different years, different ratios? Thanks Jim
Visits: 219
They are all about the same. Look for one 1988 and newer if you can. You might want to just buy a whole car, that way you get all the parts. (ie lincoln mark VII)
First 2.400 Second 1.467 Third 1.000 Fourth 0.667 Grumpy
Visits: 2.4K
Thanks so much, Grump. Happy New Year
Jim
Last Active: 8 hours ago
Visits: 38.5K
If you are not familiar with the AOD initial cable adjustment is critical. Do a search for TV oe TVI cable adjustments. There are several online. If the pressures are not set correctly the AOD can burn up in a few blocks. Chuck
Visits: 2.4K
Hi Moon I'm just doing a bit of research now, regarding trans ratios & rear axle ratios with the intent to make some changes to the car later. I'm well aware of the cable adjustment Thanks Jim
Posts: 3.0K,
Visits: 8.7K
You can change the low and second ratios in the Aod by using the parts from an 4R70W. Wish it would work in an FMX!
