Ford AOD transmission
Home
Keeping The Dream Alive!
Technical
http://forums.y-blocksforever.com/Topic119332.aspx
Print Topic
Close Window
By Kahuna
10 Years Ago
I'm wondering if any of you fellows know what the transmission gear
ratios are in a Ford AOD?
Are they all the same? Different years, different ratios?
Jim
By Grumpy1
10 Years Ago
They are all about the same. Look for one 1988 and newer if you can. You might want to just buy a whole car, that way you get all the parts. (ie lincoln mark VII)
First 2.400
Second 1.467
Third 1.000
Fourth 0.667
Grumpy
By Kahuna
10 Years Ago
Thanks so much, Grump.
Happy New Year
Jim
By MoonShadow
10 Years Ago
If you are not familiar with the AOD initial cable adjustment is critical. Do a search for TV oe TVI cable adjustments. There are several online. If the pressures are not set correctly the AOD can burn up in a few blocks. Chuck
By Kahuna
10 Years Ago
Hi Moon
I'm just doing a bit of research now, regarding trans ratios & rear axle ratios with the intent to make some changes to the car later.
I'm well aware of the cable adjustment
Jim
By pegleg
9 Years Ago
You can change the low and second ratios in the Aod by using the parts from an 4R70W. Wish it would work in an FMX!
