292 main cap bolts
Posted By redrod39 10 Years Ago
redrod39
Posted 10 Years Ago
Posts: 10, Visits: 21
I would like to know if anyone has a 292 parts motor that I can get a main cap bolt from. I lost one between home and the machine shop.
carl
Posted 10 Years Ago
Posts: 1.2K, Visits: 20.6K
redrod39 (11/6/2015)
where are you located.  Carl
redrod39
Posted 10 Years Ago
25 Holly cir, Midway,Ga 31320
Steve Takacs
Posted 10 Years Ago
Welcome to the site, Steve.
Hmmmm...  Remember that there are two lengths of 292 main cap bolts.
1955 - April (?) 1959 are the shorter bolts
May (?) 1959 [B9AE 6015-F blocks and thereafter] - 1964 are the longer ones.
The longer main cap bolts will not fit the earlier blocks unless you drill the main bearings saddle holes slightly deeper (two lip end mill cutter, not a standard drill bit) and use a bottoming tap to extend the depth of the thread to the bottom of the drilled main cap bolt hole.
Click the link below for John Mummert's listing of engine block casting ID info.
http://www.ford-y-block.com/Block%20identification.htm
Hope this helps   Smile
carl
Posted 10 Years Ago
Steve Takacs
Steve give me the length you  need and I will send you one   Carl
redrod39
Posted 10 Years Ago
Send me both, then I could send you back the other if you want. Stakman57@yahoo.com. Stecpve Takacs 25 holly cir, Midway ga,31320. Email me so I can send you postage. Do you have Paypal?
Posted 10 Years Ago
Steve: If you lay out your bolts & examine them carefully, you should be able to tell which length one is missing..
carl
Posted 10 Years Ago
redrod39 (11/13/2015)
I would be a lot easier if you just measure the ones you have so I can just ship you one,no charge   Carl
Posted 10 Years Ago
Last Active: 10 hours ago
Knowing what year block you have could help but a quick measurement on your end would simplify this.  I have an assortment of those main cap bolts in a box but do need to know the length you need so you can be helped.  As stated earlier, the main cap bolt lengths were not a consistent length during the years of manufacture for the Y engines.
redrod39
Posted 10 Years Ago
I will measure one when I get them back from the machine shop
