Visits: 14.3K
Is there any difference in physical size between the two trans? I am swapping from a 6 to a y block in my Ranch Wagon and would like to upgrade to the T85. I thought a but a T5 but I like the nostalgia of the three speed.
Durham Missouri
Visits: 22.0K
The T85 is physically bigger (and heavier) than the T86. The T86 is a light duty trans for 6 cyl and small V8 applications. The T85 is much stouter and was found behind engines up to 406 cubes in FOMOCO applications. The T85 should fit your trans tunnel with no mods needed to the tunnel/firewall. Your linkage should also work with it.
Visits: 1.4K
How can you tell one from the other from the outside?
Last Active: 5 hours ago
Posts: 1.9K,
Visits: 109.7K
The T86 is a top load trans case from my understanding. The T85 is sideload, and the bottom of the cover plate is CURVED as opposed to the other mid fifties ford transmissions being a pretty square rectangle. Google images for T85's and see what you come up with.
Daniel JessupLoveland, Ohio aka "The Hot Rod Reverend" check out the 1955 Ford Fairlane build at www.hotrodreverend.com
Visits: 74.4K
You might consider a T85 with Overdrive. Its a 30% reduction in RPMs
Visits: 110.9K
I use a T85 with OD behind my Y in my 57. My T85 was from a 61 390/401hp Galaxie. Had to change clutch disc to a 23 spline and the yoke on the drive shaft, I think the bigger output shaft on the T85 is the same size and spline as a C6..
Visits: 14.3K
The one I am looking to buy is an overdrive. I am just trying to minimize any surprises when doing the engine/trans swap.
Durham Missouri
Posts: 7.2K,
Visits: 203.0K
62bigwindow (6/4/2015)
Is there any difference in physical size between the two trans? I am swapping from a 6 to a y block in my Ranch Wagon and would like to upgrade to the T85. I thought a but a T5 but I like the nostalgia of the three speed. My ’55 Ford Customline originally had the T86 overdrive and I swapped it over to a T85 overdrive tranny in about 1990. The T85 physically fit the ’55 tunnel without any problems but I did have to modify the transmission crossmember for the relocated transmission mount and change up the driveshaft due to the different u-joint requirement.
Visits: 15.7K
If you get a T-85 make sure it comes with the tail shaft yoke.. They are very difficult to find
Visits: 14.3K
What mod did you have to do to the crossmember Ted? I assume you had to move the mount back?
Durham Missouri
