2015 Engine Masters Challenge participants have been selected.
Posted By Ted 11 Years Ago
John Mummert
Posts: 919, Visits: 7.5K
Charlie is right!  the reporting is BAD.    From what I can gather   KAASE 1st  SAM 2nd  and Ted is 3rd  right now, but  without some better clarification I can't promise this is right.  477 is probably Kaases avg hp. Not Avg. PEAK. hp
http://ford-y-block.com
MarkMontereyBay
Posts: 733, Visits: 3.8K
Yep..I stopped trying to make sense of the numbers so far. Those tasked with the media chore for the event seem to be a bit confused.
57 Black Tbird 312/auto
MarkMontereyBay
Some photos and "commentary" now on the EMC site.
http://www.hotrod.com/events/1510-you-wont-believe-this-engine-is-60-years-old/
Last Active: 4 days ago
Very interesting reading. With the Ford Y-block being wider at the manifold/head split using adapters to a narrower manifold makes perfect sense. John Kaase must have read the rules really close to figure on changing the intake port design within the confines of the head. Aluminum sure makes this easier. If that was not allowed and no aftermarket aluminum heads were allowed I'm sure he would have picked another make: Lincoln/Merc would have been a better choice just because of head design alone. I did think they (L/M) would have made a better showing. I also would like to see a single carb or throttle body of no more the 4 holes/venturi.
I feel Ted did us true Y- Blockers proud and he has proven again how stout these Fords are....Thank you Ted.
Genuinerod
Posts: 120, Visits: 33.3K
Going by the formula of Engine masters (torque + HP x 1000 / cu. in.= score.   Ted wins.  The way I figure it is Ted: 3075, Klaase: 2943, the poly eng: 2769.
CK
Supercharged (354 reputation)Supercharged (354 reputation)Supercharged (354 reputation)Supercharged (354 reputation)Supercharged (354 reputation)Supercharged (354 reputation)Supercharged (354 reputation)Supercharged (354 reputation)Supercharged (354 reputation)
Posts: 152, Visits: 1.1K
I think Kaase ran his Y block in two classes and that is why its mentioned having two HP stats.
477Hp cut off at 6000rpm Vintage class
600HP, well that's peak HP and has been compared to LS engines having a greater Torque figure and what 50 plus years have done for the V8.
John I think your heads really opened the worlds eyes on the old Y.
But The EMC site is shocking and hoping Genuinerod is right
glrbird
Posts: 616, Visits: 7.1K
http://www.hotrod.com/events/1510-prehistoric-power-the-winner-of-vintage-class-competition-at-2015-amsoil-engine-masters-challenge/
kaase won
sam second
ted third
Packard fourth
Royce fifth
Gary Ryan San Antonio.TX.
THANKS for posting that, Gary.
Ted's performance and Royce's were EXCELLENT.  We'll all be interested to hear what they put together in their engine builds.  As has been said earlier, some of the EMC reporting is incorrect.
For those of us that have not followed John Kasse, I found the article that follows on the Internet.  Click the link if you're interested in a profile of his performance engine operation.
http://www.jonkaaseracingengines.com/html/about.html
Kasse, Ted, and Royce have breathed new life into the y-block story.  That said, John Mummert has provided THE cylinder heads that have revolutionized the capability the 'little' y-blocks fielded by John Kasse and Ted.
Kudos to all of the vintage category EMC participants on their accomplishments.  WoW!  What a showing!
glrbird
Ted and Royce have plenty to be proud of, Competing against Kaase is tough, lots of money and equipment to build what ever he needs.  I wonder if Royce is thinking tunnel ram now.
Y block Billy
Posts: 1.6K, Visits: 5.2K
Ya, John adden 10 lbs of welding rod to the heads and reported them to side by side ports, talk about going to extremes!
55 Vicky & customline
