2015 Engine Masters Challenge participants have been selected.
Posted By Ted 11 Years Ago
John Mummert
Posts: 919, Visits: 7.5K
I'm not sure but I think its got side by side ports.
http://ford-y-block.com
LordMrFord
Posts: 687, Visits: 9.3K
That would be something.
I forget that he uses alu heads.
Aluminum is much easier to modify that way than cast iron.
Hyvinkää, FI
glrbird
Posts: 616, Visits: 7.1K
Mr. Mummert, are you talking about the head?
Gary Ryan San Antonio.TX.
Rowen
Posts: 435, Visits: 29.3K
Any word yet on the vintage class? Rowen
Rowen
55CV
Woodland, Ca
Grumpy1
Turbocharged (74 reputation)Turbocharged (74 reputation)Turbocharged (74 reputation)Turbocharged (74 reputation)Turbocharged (74 reputation)Turbocharged (74 reputation)Turbocharged (74 reputation)Turbocharged (74 reputation)Turbocharged (74 reputation)
Posts: 35, Visits: 219
Go to hod rod magazine.  Engine masters challenge 2015.  Looks like Jon kasse won.
Im hoping Barry Rabotnick with his Fe runs well and possibly beats the big blocks tomorrow.
MarkMontereyBay
Posts: 733, Visits: 3.8K
Edit; Kaase made 477HP 557TQ average on 3 pulls, the Lincoln did 463HP, Ted did 542HP. The Packard made 445HP. I can't find anything on Barry's FE. I think he is running tomorrow (Friday).
http://www.hotrod.com/events/engine-masters-challenge/
57 Black Tbird 312/auto
Excellent Ted. I think you gathered some attention with that. Even Kaase had to be impressed!
MarkMontereyBay
Yep... I am rereading the report online and it says that Kaase reached nearly 600 peak torque with the 557 being an average over three pulls. The HP number is 477.
Ted's torque wqs 496.
Rowen
Do you think the ports twist from the heads to the intake inside that adaptor? Some serious engineering going on there.... Rowen
Rowen
55CV
Woodland, Ca
The reporting on the event is terrible.  In one article,  it says Kaase was 477hp.  In another it says 583.  All the numbers they've provided are average peak numbers which is not at all relevant to the scoring system.
Ted's engine is indicated to have made the exact same hp and tq as the Poly 318, and has LS7 HIlborn efi, factory cast iron heads, ported, according to the report.  While it is certainly possible that it produced the exact same numbers as another engine, it is not very likely and given all of the other errors, I'm sure that is a mistake as well.
So at this point, we don't really know how it has turned out.  IF the numbers reported are correct, then Ted has won as Kaase did not produce enough power and torque for his displacement.  That's IF they are correct, and my guess is they are not.
I hope there is a results article or summary with accurate info.  Or maybe Ted or Royce will chime in with the real scoop.
