1956FORDFAIRLANETOWNSEDAN2...
Visits: 13
What did the Original Holley Teapot 4000 flow at cfm wise? What is a better option carb for a 292 y block should I go with the Holley 390cfm or an edenbrock 500 cfm performer series?
shakey
Visits: 434
tried a 600cfm holley4 barrel on my 292 lots of soot out the tail pipe , change to a 400 cfm holley 4 barrel works great shakey
I've only used a 600 Edelbrock. It worked ok on an 292 that was more or less within stock parameters, aside from the cam. The 500 will probably be alright. I don't agree with the general opinion that they are easier to tune. If all you need to do is change metering rods, then it is very easy, but when it comes to changing jets, it is a lot more involved than a Holley. Edelbrocks also are not generally as tuneable as many Holleys. My use was on a truck. Aside from having the appropriate intake or an adapter to use with your current intake, I can't tell you what else you will need to make it work.
speedpro56
Posts: 1.3K,
Visits: 9.2K
Tuning the Edelbrock is different, Charlie may chime in on this but make sure you use a later model intake manifold and the Edelbrock should work fine.
-Gary Burnette-
Visits: 13
Gary,
Thank you for the reply. How is the edenbrock performer 500 CFM with an electric choke option? What all needs to be done for this to work
speedpro56
Posts: 1.3K,
Visits: 9.2K
The 390 cfm Holley will work fine but you will need to change the original loadamatic distributor to a 1957 or later as well. Usually the front primary jets of the 390 Holley will need to go up a few numbers and as to the question on the cfms on the teapot they flow around 370 cfms and the one off a Lincoln they flow around 390 cfms according to Pony carbs.
-Gary Burnette-
Visits: 13
Currently looking for a new 4BB carburetor and need help - Edenbrock 1403 Performer Series 500CFM with an Electric Choke or the Holley 4160 Part number 0-8007 with a 390CFM on a 1956 Ford Fairalne 292?
I have a Ford Fairlane Town Sedan with the original Holley Teapot Carburetor and the original yblock 292. How many CFM's did the teapot Holley produce with the 292 and what is RPM for the 1956 Ford Fairlane. I think my vehicle is around 4700RPM or 4900RPM, currently the gauge is not working. I had the carburetor rebuilt, but gas keeps pouring out the top and I'm told this has been done to many times before me owning the vehicle. Therefore I'm looking for a new carb and am looking at the Edenbrock 1403 500 CFM with an electric choke or the Holly 4160 part number 0-8007 which is 390CFM. I'm told that 500CFM may be overpowering I'm just not sure if it will be. I just need help picking the right carb. I'm not going to be using the Fairlane to race, just as a daily and weekend cruiser. What is good range CFM for me to choose and what carburetor would you tell me to go with?
Thank you,
Jason
2721955meteor
Visits: 190.0K
I run a 600 holley on my 57ranchero 292 ,it runs perfect out of the box,good power corect port for dist,always starts instantly when hot.
Campsite
Visits: 632
Good evening; Just to add my two cents worth, And I do not need to be shouted at. Is For my 312 That is a not stock, I Bought a Holley, that was a Ford service Replacment, Carb It was for a 289 High Performance, A 289, yes it is a smaller engine, BUT it does, Breathe about the same. The part number is D0PF 9510-U List 4548 2983 I bought it new. And yes I have seen this Carb on E-bay. If you can find one, it should work well on a 292 .The Carb works well thru all the RPM ranges.
Looks good on a FORD
Bob
Y block Billy
Posts: 1.6K,
Visits: 5.2K
The holley 600 that were installed on trucks and were originally governed were very fat on the fuel, I tried a setup on my vicky once with the matcing distributor and it would smoke the tires so easily off line but cut out at 3800 rpm, governed setup and it was jetted real fat, gas would pour out the exhaust. Got to have the right carb and right jets!
