Flywheel and Drive plate replacement
Posted By DAllen1088 12 Years Ago
DAllen1088
Problem Posted 12 Years Ago
Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)
Posts: 2, Visits: 9
Hello all, This is my first post here..
on my 272, there are 2 drive plates on the flywheel, the drive plates bolt to the torque converter.  on the torque converter is the gear ring.  Well, i broke one of the drive plates, and im looking for something to replace the flywheel... i cant seem to locate what i have... i need some help... :-)
Doug Allen
slick56
Posts: 463, Visits: 4.5K
Welcome Doug, this is the place to find the answer.
Until someone chimes in with a specific answer, you may like to check the search function...
If you type in "flex plate" in the 'search discussions' box on the upper right of this page, it will take you to a new page, then
If you then click on Advanced and click on the down arrow next to 'using ANY keywords' and then click "using ALL keywords',
that will narrow the results down some.
Good luck
South Australia
Posts: 3.7K, Visits: 323.8K
The flywheel you have was used from '54-'56.  They are not available new.  The '57 style "flex plate" as they are called are available from the early Ford and early T-Bird parts vendors.  It will be a nearly flat steel plate, nearly square, about 3/32" thick, and will bolt to the converter with four bolts instead of the 6 bolts in your current setup.
DAllen1088
Posts: 2, Visits: 9
Thank you for the responses... I saw the one on tee-bird.com, Part # 6375A....wasnt sure if it was the right one....
