Camshaft lifters
Posted By RayCarter18 12 Years Ago
RayCarter18
Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)
Posts: 174, Visits: 1.7K
Is there a reason you need to replace the lifters if you replace the camshaft? If so what is the reason or can the used ones be reused.
Posts: 7.6K, Visits: 206.1K
Here’s the link to a past thread giving several other links regarding the subject of used lifters.
http://forums.y-blocksforever.com/FindPost66378.aspx
But in direct response to your question, reusing lifters that have already been run is not recommended for use on a new camshaft.  There are lots of reasons for a new camshaft to fail and using previously run lifters on a new camshaft is just one of the reasons.  The big risk is the lifters turning in the opposite direction in which they had been previously run.  Assuming the tappets are used in the same locations, then if the lobe rake angles have been reversed from one camshaft to another, then lifter rotation also reverses.  Any reduction in crown on the used lifters is also a deterrent for the new cam lobe break-in.  Beyond all that, here’s the link to a list of contributing factors for cam and lifter failures.
Cam and lifter failure causes
RayCarter18
What about Having them re-ground? Does that make them reusable cause it is a lot cheaper than buying new ones ,from my understanding.
aussiebill
Posts: 1.8K, Visits: 11.4K
RayCarter18 (6/22/2014)
Ray, there will be variable opinions but has been industry practice since the 60,s to re radius the lifters, same as regrinding crankshafts.
 Down Under, Australia
RayCarter18
Forgive my lack of knowledge but what is reradiusing the lifters?
slick56
Posts: 463, Visits: 4.5K
The lifters are not flat,  they are machined with a slight convex so that they rotate on the camshaft.
South Australia
RayCarter18
So is there any issue with having them re ground does it take off enough to cause a push rod issue does it hurt them to be reground ?
Posts: 4.6K, Visits: 39.5K
I think the hardest part is finding a machinest that can re radius them or even understands what that is. Sort of a Y-Block thing I guess. Chuck
Riz
Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)
Posts: 177, Visits: 4.4K
They're not that expensive, if you are going through the work to pull them out a new set will be worth eliminating one way to wipe out the cam.
Cheap insurance if it avoids tearing it apart again.
Mike Rizzo
1963 F100 "Rudy"
Daniel Island, SC
2721955meteor
Posts: 927, Visits: 190.0K
all flat tapet camed engines hyd or meckanical have convex lifters,even diesel engines.the cam grinders hear in vancuver have a fixture for doing the job.last set i had machined it was 5 dollers per lifter. they ar fusey about which ones they will do
