Mummert Ram Horn Exhaust Install/Bolts
Posted By Outlaw56 12 Years Ago
Y block Billy
Posts: 1.6K, Visits: 5.2K
Now as my memory is coming back, I had to whittle/file a contour in the manifolds over the spark plugs in order to get a plug socket on the plugs in some locations.
55 Vicky & customline
stuey
Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)
Last Active: 10 Months Ago
Posts: 444, Visits: 3.8K
just finished installing ram horn manifolds, these are on ally heads. i found i needed 3 at 1.5" and 4 at 1.75"  i tried 3 at 1.75" and 4 at 2" but these bottomed out.
stuey
Outlaw56
Supercharged (926 reputation)Supercharged (926 reputation)Supercharged (926 reputation)Supercharged (926 reputation)Supercharged (926 reputation)Supercharged (926 reputation)Supercharged (926 reputation)Supercharged (926 reputation)Supercharged (926 reputation)
Posts: 436, Visits: 26.9K
Ted,
If I understand correctly, you favor no gaskets when using cast iron exhaust manifolds on cast iron heads. John Mummert recommends (4) 1 1/2" bolts and (3) 2" bolts to install his manifolds. Would this not using a gasket change this length?
HT32BSX115
Supercharged (593 reputation)Supercharged (593 reputation)Supercharged (593 reputation)Supercharged (593 reputation)Supercharged (593 reputation)Supercharged (593 reputation)Supercharged (593 reputation)Supercharged (593 reputation)Supercharged (593 reputation)
Posts: 452, Visits: 24.4K
Outlaw56 (4/28/2014)
When installing intake manifolds without a gasket, how would you block off the port under the carberator to minimize heat damage to the paint on the intake manifold when not using a gasket?
I don't think anyone is referring to the intake manifold.  I think we're just talking about the exhaust manifold aren't we?
1955 F-600/272/E4OD// Disclaimer: No animals were injured while test driving my F-600 except the ones I ran over intentionally!
This post was created using OpenSuSE Linux x64 and Firefox
Outlaw56
Your right, I got off track on that one. Looks like I hijacked my own thread. I will clean that post up with the "edit option".
Posts: 7.6K, Visits: 206.1K
Ted, If I understand correctly, you favor no gaskets when using cast iron exhaust manifolds on cast iron heads. John Mummert recommends (4) 1 1/2" bolts and (3) 2" bolts to install his manifolds. Would this not using a gasket change this length?
Bolt length will not change if gaskets are not used.  A thin film of red high temperature RTV in lieu of a gasket wouldn't hurt.
Here's the link to a previous thread discussing the truck exhaust gaskets which did not use any sealer on them.
http://forums.y-blocksforever.com/FindPost5884.aspx
Outlaw56
Thanks Ted! I have a really hard time with the search options and posting pictures with the new software. If I could navigate thru the search better, I would not have to post so many "new topics" that are already covered.
