Transmission adapters
Posted By uncleaud 17 Years Ago
uncleaud
Posted 17 Years Ago
Turbocharged (62 reputation)Turbocharged (62 reputation)Turbocharged (62 reputation)Turbocharged (62 reputation)Turbocharged (62 reputation)Turbocharged (62 reputation)Turbocharged (62 reputation)Turbocharged (62 reputation)Turbocharged (62 reputation)
Posts: 62, Visits: 863
I'm looking to put an overdrive tranmission behind the 312 in my 57 Tbird. The only two companys that I can find that make the adapters are Wilcap and Berndsten (not sure of that spelling). Has anyone had any experience with either of the two adapters or does anyone know of any other companys that do the same sort of thing. Thanks
Posted 17 Years Ago
Here’s contact info for a couple of more companies producing AOD adapters for the Y.
Randy Ruzicka at:
Hollywood Automotive, Inc.
3360 Roger Pl.
St. Louis, MO 63116
(314) 773-3333
Gary Croan at:
Bristol Services
711 West 17th Street, Suite F11
Costa Meca, CA 92627-4354
(949) 722-1122  9AM-10PM Pacific Time
yblock32deuce
Posted 17 Years Ago
Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)
Posts: 173, Visits: 1.5K
am using the bernstein (?) adaptor on my 54 merc with 292 and aod, as nice a piece of merchandise as i have ever used. fit perfectly, looks good, maybe a tad pricey but.........
Posted 17 Years Ago
Ted,
   I eMailed Randy a couple of weeks ago, he hasn't finished his adapter yet.
Posted 17 Years Ago
Last Active: 30 minutes ago
Posts: 3.7K, Visits: 323.2K
Uncleaud:
Back to your initial post.  Are you looking to put an automatic overdrive or standard shift with overdrive in your Bird?  Makes a lot of difference in the adaptor required.
John
Posted 17 Years Ago
pegleg (2/16/2008)
Ted, I eMailed Randy a couple of weeks ago, he hasn't finished his adapter yet.
Thanks for the update on Randy.  Did he happen to mention how far off he is from being in a position to actually ship some units?
Hoosier Hurricane (2/16/2008)
Uncleaud:
Back to your initial post.  Are you looking to put an automatic overdrive or standard shift with overdrive in your Bird?  Makes a lot of difference in the adaptor required.  John
Good point John.  As is already known, there are enough nuances between the auto and standard transmission setups for the SBF that there is not a clean interchangability between the two with the same adapter.  The Bendtsens adapter comes to mind as it works with the AOD but not very well with the standard trans conversion.
Posted 17 Years Ago
Ted,
             I asked, but got no answer. I don't think he's actually working on it.
uncleaud
Posted 17 Years Ago
Sorry bout the delay...your right I been researchin...My plan is to put a 200 4r or a 700 r4 behind the 312...I know I know they aren't Ford but I have them and I really like the gear ratios they provide...Right now I am lookin at going with the Wilcap because its 300 bucks cheaper and all I have to provide is the starter which I'm thinkin I can do for the difference in cost. If I'm not mistaken they are the same starter Chrysler has been usin for years and there are a ton of them out there. I'v got to get the two pieces dummied up if I can and see what has to be fabricated for the rear mount. If I have to start cuttin the x bracing then I will go another way. This Michigan winter has been slowing down my garage time in the evenings. Has anyone had any bad things happen with Wilcap?
Pitewagon
Posted 17 Years Ago
Hitting on all eight cylinders (23 reputation)Hitting on all eight cylinders (23 reputation)Hitting on all eight cylinders (23 reputation)Hitting on all eight cylinders (23 reputation)Hitting on all eight cylinders (23 reputation)Hitting on all eight cylinders (23 reputation)Hitting on all eight cylinders (23 reputation)Hitting on all eight cylinders (23 reputation)Hitting on all eight cylinders (23 reputation)
Last Active: 15 Years Ago
Posts: 23, Visits: 219
I just bought a AOD-kit from Bendtsen,very pleased with everything,
But,will modyfy to fit 4R70W(at least tryBigGrin)
Pitewagon
Fredde
Pitewagon Piteå Sweden
sundance241
Posted 17 Years Ago
Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)
Posts: 202, Visits: 1.4K
Uncleaud,   I installed a Bendtsens  700R  trans. adaptor  to the  292 in my victoria..... no problems ,  . very well made ,   more than i wanted to pay ,  but........... .   Have you given any thought to what gear racio  for the rear end ....My car has a 322   and i think   i need a 350  or 360 , in that range ...Any thoughts on that  .......? ..............Sam
56 victoria
