Last Active: 6 days ago
Visits: 3.4K
In my valley cover, there was a "stud" that the screw would screw into. this "stud a' was/is spot welded from the bottom side of the valley cover. I removed the thing from the bottom side, then welded up the small holes where the spot welds were ( 3 of them ). probably did not need to as they were very small, and there is a baffle there. after this is removed a pcv valve and a rubber grommet can be installed directly into the valley cover with no problems. when I get back into town where my car is, I will try and take some pictures, if any one wants to see them.
Visits: 3.6K
Yes, I misused the term "stud". It is a threaded insert for the hold down screw that is pressed in and spot welded from the bottom. I want to avoid pulling the intake if possible.
Visits: 3.4K
I had to remove the valley pan. I could see no other way to remove the "stud" without damaging the valley cover.
Visits: 3.6K
Visits: 190.0K
i removed the pcvvalve .instead piped the hose into the air cleaner so not going into the carb base. the fiting is past the air filter so does not plug the air filter'i use a after market air cleaner with a dry element. it al lhandels base pressure very well . just block the fitting into the holley carb
