stuey
Visits: 3.8K
Posts: 6.1K,
Visits: 442.8K
Full of misinformation.
darrell
Visits: 22.2K
55 dist,on newer carb.not one person that posted saw it.i was going to post but impossable.
Posts: 6.1K,
Visits: 442.8K
I commented on several things, including the distributor.
Last Active: 4 hours ago
Visits: 306.3K
This was a stock rebuild with a few modifications. What did you find objectionable? The LOM DIST was retained most likely as for an original appearance/cost of tach drive DUAL ADVANCE replacement. The DIST can be modified to deliver proper performance. TED EATON retained the LOM DIST on his 1955 P-CODE 292 rebuild.
Visits: 306.3K
Including this dumb SOB ...
I saw the MUMMERT INTAKE. I did not connect the later carb with the advance signal. My bad. I will stand down.
If one is doing a purely stock rebuild for a street driver, why an ALUM INTAKE, with no heat riser provision yet? The engine was not modified for deeper breathing or high RPM.
Maybe an '56 A or '57 B INTAKE with adapter for the H4000 (with choke modifications) or a BLUE THUNDER?
Posts: 6.1K,
Visits: 442.8K
in addition to the distributor, the unnecessary oiling modifications, stating that the head gaskets are specific to the left or right side, stating the wrong bore diameter, not knowing what the over flow tubes do, very likely incorrect combustion chamber volume. That's what I can remember I'll acknowledge that some of it is nit-picky but if you look at the comments, there seem to be a lot of newbs who are taking it as irrefutable fact, particularly since someone of note, Keith Dorton, is doing the build. In this regard, any errors are bad. Any errors are bad, no matter who is involved but if it was just some random guy that no one has heard of, they might be more hesitant to believe it. They also referenced his previous build which came up far short of the power it should have produced considering the work and parts involved. If they look that one up, that adds to the bad ideas / advice.
Posts: 4.6K,
Visits: 38.3K
When someone is tagged or volunteers to do an article on any specific engine they should at least be informed about the engine they choose. This article was pretty much the same error filled stuff we could read in the 50's. I'm sure the intake was "eye candy" and was given no real thought as far as flow. Maybe easier than trying to source the later style intake for the carb upgrade. I'd love to see one of our enlightened and informed Y's guys write an article like this but with the real truths about our favorite engine.
Y's guys rule! Looking for McCullouch VS57 brackets and parts. Also looking for 28 Chrysler series 72 parts. And early Hemi parts.
  MoonShadow, 292 w/McCulloch, 28 Chrysler Roadster, 354 Hemi) Manchester, New Hampshire
dbird
Visits: 4.0K
The distributor was my first thought, but the intake/heads combination seems wrong. The heads appear to be for a 1955 272, though they could be original to the car. However, spending the money for a high dollar rebuild and not getting better breathing heads with ports that would better match up to the intake seems wrong, especially if I were looking at it and thinking it had the wrong heads on it anyway.
Don
Visits: 306.3K
You're right ...
I must be retaining water this week ...
