aussiebill
Posts: 1.8K,
Visits: 11.4K
TED, thanks for clarifying my suggetions and the guys have clearer understanding. Your word for word answer described the problems of the 4" sleeve/deck problem and furnace brazeing is unaailable here also, hence i,m not holding out for success with my 4" er, fingers x,d. Allways look forward to your clinical and precise explanations, best regards bill. P.S, is it just me or site, when typing, some of the letters are missig in the words and have to be retyped??
lyonroad
Visits: 3.1K
[b]. P.S, is it just me or site, when typing, some of the letters are missig in the words and have to be retyped?? Its not you Bill. ts ben going on for some months now.
Mark
mctim64
Last Active: 5 Months Ago
Posts: 2.4K,
Visits: 5.0K
Yes, I did not have good luck with the eight thick walled sleeves and a 4" bore. Ran great for a couple of passes and then went to pumping water. A lesson learned the hard way, and that was with a solid filled block.
gekko13
Visits: 2.6K
Just wondering out loud, could a solid copper (no coolant passages) head gasket have prevented that?
LordMrFord
Visits: 9.3K
mctim64 (2/19/2014)
Y-Block bored to death.
Some Turbo-Nissan guys use steel plate sinked in top of the block. Supports the cylinders from doing that when they take 600hp from engine what weights about same as one the Y-Block cylinder head.
 Hyvinkää, FI
mctim64
Posts: 2.4K,
Visits: 5.0K
gekko13 (2/19/2014) Just wondering out loud, could a solid copper (no coolant passages) head gasket have prevented that? Nope! Tried that.
aussiebill
Posts: 1.8K,
Visits: 11.4K
mctim64 (2/20/2014)
gekko13 (2/19/2014) Just wondering out loud, could a solid copper (no coolant passages) head gasket have prevented that? Nope! Tried that.  Tim, although starting 4 " project some 15 yrs ago, ive just been at it on/off, covered up till next time. As i,ve seen ted and your results i hold no happiness in ts future, but will see i i can add it to the pile. yyy
I wonder if you could us some high grade all thread rod for head studs that go all the way through and tie the upper and lower portion of the water jacket together. Or maybe dowels in the upper an lower portion of the sleeve. Maybe the head bolt bosses would have enough meat up top. Not sure about the bottom. Both will have challenges but may be possible.
ian57tbird
Visits: 21.7K
Is the block deck flexing as it is no longer tied to the lower part of the block?
CK and his 55Tbird
Visits: 273
A few years back I came across a set of diesel sleeves which were stainless steel and about 040" thick with a rolled lip at the top which is what held it in place.Perhaps with something like this the original bore can be left in place and machined to fit a slimmer steel sleeve.
