Visits: 3.1K
CK (5/1/2014)
A nd i'm envious of the booster fitment, I'm pretty sure it won't fit the tbird quite the same.
Thanks CK. The aluminum plate at the back of the booster is an adapter I made that raises the booster a couple of inches. The booster and master cylinder now clear the exhaust manifold by a lot. I had to add the plate because the two push rods that came with the booster didn't fit. One was too long the other too short.
Mark
Visits: 1.1K
Hi guys Curious how others went with these headers? I've found the bolts continually loosening up and thinking of getting a better set which may hold tension under such conditions. Any suggestions?
Visits: 21.7K
I have not installed mine (not sure if I ever will) but you might consider getting some stainless star washers or a bit of Loctite. I think you have the alloy heads so make sure they are in deep enough. I would also be tempted to go to bolts with a larger head and a star washer. The bolt they supply are not very good quality, if you check the threads you can see that they have a course finish and probably not good for alloy heads. What they supplied is 3/8UNC x 1" long and you could go to 1 1/4" long if you needed with a full 9/16AF head. The only hole that you might struggle to fit 1 1/4" long is the second hole back on the left bank, 1" with a 9/16 head fits as I tried it but it was close, maybe 1 1/8 long might fit if you needed a bit more length. Stainless changes size more with temperature changes so that might help to work things loose as well.
Visits: 14.3K
I just talked to him via email and he said he would ship to the states for $150 aud. Not sure what the conversion rate is but it might not be a bad deal.
Durham Missouri
Posts: 1.8K,
Visits: 11.4K
The conversion rate is your way, aussie $ is about 77 cents US.
Visits: 14.3K
I am glad I went through and reread the post.I was getting ready to buy a set from him and seen that they wont work on the sedans. Thunderbird only. Bummer, the price was pretty good with the echange rate.
Durham Missouri
