5752-113 porting
Posted By CK and his 55Tbird 12 Years Ago
Woody
Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)
Posts: 31, Visits: 269
slick56 (1/27/2014)
lyonroad (1/26/2014)
Too bad, they look good. The Canadian/Australian exchange rate is favorable but the shipping would be a killer. Just out of curiosity do they fit sedans? They kind of resemble Tbird headers. My brother in law will be in Wollongong in a month or so.
I will email him tonight to see if he knows if they will fit a full size Ford, if so i will order a set and keep you informed.
Those short headers look great! I am in Sydney area so happy to take my car around to check fitment if the guy is not sure. Just looking at them I suspect they would not fit a Customline/ Mainline engine bay but you never know....
Good luck with the mods CK.
Cheers, Woody.
CK and his 55Tbird
Supercharged (231 reputation)Supercharged (231 reputation)Supercharged (231 reputation)Supercharged (231 reputation)Supercharged (231 reputation)Supercharged (231 reputation)Supercharged (231 reputation)Supercharged (231 reputation)Supercharged (231 reputation)
Posts: 104, Visits: 273
Doug T (2/3/2014)
http://forums.y-blocksforever.com/Uploads/Images/099b0f24-53d8-451d-9bf5-cecc.JPGI Think you can do a bit more in the exhaust side of the head. Here is a pic of a G head sectioned to show the exhaust port. Notice that the black sharpie line on the long radius side of the head runs from the edge of the guide to the center of the ex port flange. You can remove all this. You can also widen the port a bit to get it more round in appearance. The drilled hole shows a lot of material. I found that the biggest improvement was from putting in larger ex valves, I used 1.6" scrub valves that were 0.200" longer but now you can get exact fit valves from John M. The marks on the ex valve and bowl show where to grind a little undercut but removing too much causes loss of compression.
This pic shows the kind of shape I wanted at the exhaust flange. The top manifold in the pic has already been done the bottom one is marked for grinding. I matched gaskets but these days for manifolds like this I would just use HT silicone.
http://forums.y-blocksforever.com/Uploads/Images/75a1592d-8959-4148-bc12-5e1b.jpg
I developed these ideas and some others using a home made flow bench in the early 1990's
This looks amazing. well done.
http://forums.y-blocksforever.com/Uploads/Images/071ce014-220e-451b-a2b9-160e.jpg
Finally if you are going to have fun porting don't forget your special Y Block Goggles
http://forums.y-blocksforever.com/Uploads/Images/00a90e7e-1bd9-479e-bca4-709b.jpg
CK and his 55Tbird
Consider potential energy and Kinetic. My theory is that if a good engine may convert 15-20% potential energy into kinetic then this should be the difference in port sizing.
ie. 2.02" In. and 1.6" Ex. the difference would be about 20%. So the volume of fluid induced is then aimed at and 20% less volume exiting the cylinder after heat conversion. obviously if you altered this formula you would be estimating a more efficent cycle.
So I have left std. valve 1.92" and 1.54" and gave a mild port to match a mild cam.
CK and his 55Tbird
http://forums.y-blocksforever.com/Uploads/Images/00a90e7e-1bd9-479e-bca4-709b.jpgGlad I have myself a pair
