Park Olson
Visits: 1.9K
My '56-'57 book shows TAAA 7515B for '56 and B7C 7515A for '57,,,,,10 5/8 and 11 1/4 approx. length respectively
Cool! So it looks like '54-'56 and '57-'64 are different.
lyonroad
Visits: 3.1K
Rono (1/17/2014) So would car clutch forks have a different ratio and if so, why?
RonoI agree with Horvaths. Probably for increased leverage. Some trucks had 10.5", 11" and 12" clutches (pressure plate springs were different). Also cars had the big helper spring on the pedal while trucks had the through the floor thigh-master style pedal.
Mark
The Horvaths
Visits: 1.3K
Same casting as mine but I measured with a rule and one eye.
lyonroad
Visits: 3.1K
charliemccraney (1/18/2014) See how it compares to the dimensions we've posted and the number on it.The number is TAAA-7515B. Dimensions are 5 3/4" x 3 3/8". I measured with set of dividers. The fork is from a '56 Mercury M100 witha 272, 11" clutch and a light duty 3 speed trans. Hope this helps
Mark
slick56
Visits: 4.5K
This is from a bellhousing off a B9 block with hydraulic clutch. I do not know if that would make a difference to the pivot point. I also do not know how big the truck was.  From pivot point to throwout bearing c/l is approx 3-1/4" From pivot point to clutch rod c/l is approx 6-1/4"  Part no. is TAAK-7515-B .
South Australia
lyonroad
Visits: 3.1K
Charlie, I have a '56 clutch fork (at least it came in a "56) in the back shed. I can look at it tomorrow. What would you like me to check?
Mark
I looked in my'57-'66 Truck parts catalog and any of those trucks with a Y would have used the same fork, part number B8C-7515-A (The numbers we gave above are engineering numbers), about 11" long, which matches my spare. I wonder if the other fork is '54-'56?
The Horvaths
Visits: 1.3K
I reason (aloud) that, for a given transmission/bell housing, the distance from pivot to throw out will be the same. Then the distance from pivot to rod could be varied. This would cause a change in rod (pedal) travel, and a change in foot pressure required to overcome a given set of springs in the pressure plate.
